Wet Drivers Seat Belt
Ok I have a sun/moon roof, factory in my 96GS . Whenever it rains my seat belt is wet. Anyone else have this problem, Thanks.
Re: Wet Drivers Seat Belt
Keep the sunroof closed when it rains.
Nd4SpdSe wrote:Keep the sunroof closed when it rains.
Your always so helpful :(
It gets wet inside the pillar where the retractor is.
Lol, sorry, I had to throw that one in...
I don't have a sunroof so my info is quite limited, but I believe the main cause is usually clogged drainage tubes
fowljesse
Post by fowljesse »
The sunroof drain tube goes down through the B pillar, and drains behind the front seats. I thought it went down the passenger's side. It sounds like it got plugged, or came loose. You need to take down the headliner, and follow the drain tube.
Good luck. If you don't find anything wrong, Saran Wrap your shoulder when it's wet out.
fowljesse wrote:If you don't find anything wrong, Saran Wrap your shoulder when it's wet out.
Hey how about we saran wrap your head Mr Silver Surfer. :)
ninjajim4
Post by ninjajim4 »
fowljesse wrote:The sunroof drain tube goes down through the B pillar, and drains behind the front seats. I thought it went down the passenger's side. It sounds like it got plugged, or came loose. You need to take down the headliner, and follow the drain tube.
there's actually drain tubes at all four corners, so i'd guess it's leaking out the back driver's side corner. either that or you need to stop driving shirtless with your damp, sweaty, tom sellick chest
fowljesse
Post by fowljesse »
*Yawn*
Been there......
Damn perspiration wetness, never thought it was an issue. OK I'll see if I have a leaky drain tube. At my age you can never bee too cautious.
