(FS/Trade) Wilwood Big brake kit in NY for MINT SE seats +$
Georonimo
Post by Georonimo »
These brakes have a total of 700 street miles on them. A new engine was installed at the same time these brakes where so they are all pretty much break in miles.
This setup consists of modified 95 EGT spindles that have been powdercoated, wilwood 4 piston brake calipers, willwood 2 piece 11" rotors, Russell stainless brake lines, new oem hubs, ARP chromemoly wheelstuds, new oem hub bearings, new ball joints, new tie rod ends, and a pair of custom machined 8mm aluminum spacers. With the spacers installed these brakes will clear both 95 EGT and 99/2000 ZX2 S/R wheels (both 15 inch). I havn't tried any other OEM wheels on them.
I weighed these spindles at 29.4 pounds as pictured with ball joints, tie rod ends and brake lines. I weighed worn out stock components and got a weight of 36lbs even. Thats 6+lbs weight saving per corner for you autox'ers and the like.
The price is $1200 outright or I'll deduct a couple hundred for a showroom condition set of SE front seats. The seats must be in absolute perfect condition or I am not interested.
Here are some pics that where taken before installation. I'll take some current pics tomorrow or some time this weekend showing all components, brake lines, and the spacers.:
(Scroll down for current pics)
Last edited by Georonimo on September 13th, 2008, 2:33 pm, edited 4 times in total.
Re: (GI) Wilwood Big brake kit in NY
Those sure look purdy. Do they take the small 1992 or larger shaft ball joint?
Georonimo
Post by Georonimo »
These spindles use the smaller ball joint. The escorts didn't get the larger ball joint till 97 (3rd gen).
fieromx3
Post by fieromx3 »
price
93' MX-3 GS-ZE
14.4 @ 96.7
14.5 @ 97.2
Georonimo
Post by Georonimo »
Crunched some numbers and I would need to get 1200 in order to sell these.
And the spindles may actually be third gen escort spindles with the larger ball joint. I'll confirm tomorrow when I take the pics.
colinsmx3
Post by colinsmx3 »
as long as you confirm everything will fit and be OK you may have a buyer!
Georonimo
Post by Georonimo »
colinsmx3 wrote:as long as you confirm everything will fit and be OK you may have a buyer!
Everything will definitely fit. It would just be a matter of what year ball joint would work with these spindles. I took a quick measurment and came up with a 15-16mm diamater. I beleive that is the later style ball joint.
Here are a few pictures of the parts in their current condition (with 700 street miles). What is pictured is what's included.
Here are some pics of these brakes behind a few 15 inch wheels:
Stock 95 Escort GT 15's w/8mm spacer:
Stock ZX2 S/R 15's w/8mm spacer:
15x7 BBS wheels with a 41mm offset and 8mm spacer (will also clear with out the spacer):
I'll provide the buyer a list of part numbers for service and replacement parts.
All items are readily available from SummitRacing.com
If anyone is serious, feel free to give me a call. 845-242-5173
mx3autozam
Re: (FS/Trade) Wilwood Big brake kit in NY for MINT SE seats +$
Post by mx3autozam »
Whats the deal on these. Looking at that spindle it doesn't even look modified at all. Are these some sort of direct fit wilwood brakes that you got somewhere. I have EGT wheels on my mx3 and these brakes would look awesome behind them.
93 Mazda MX3 KLZE Turbo
Georonimo
Post by Georonimo »
mx3autozam wrote:Whats the deal on these. Looking at that spindle it doesn't even look modified at all. Are these some sort of direct fit wilwood brakes that you got somewhere. I have EGT wheels on my mx3 and these brakes would look awesome behind them.
There was quite a bit of work done to these spindles in order for them to accept a standard Wilwood Dynalite caliper. The mounting ears where first cut down and rounded. The original holes where filled in and new holes drilled in the proper location for Wilwood calipers and 11" rotors. The ears where then milled to space the caliper properly and threaded steel inserts where pressed in. After test fitting everything the spindles where dissasembled, sand blasted and powder coated.
