FS: ZE Block
mikeseli
FS: ZE Block
Post by mikeseli »
This is a complete ZE block with pistons,rings, water pump, oil pan all you need is two head and the IM and you have a complete engine.<p>I'm asking for $400Cdn or $300US for it. <p>Before I took my heads apart and sold them, I performed a compression test and got between 180-185 on all six cylinders.<p>The reason for sale is because my PGT is for sale so I installed my stock 03 engine.<p>If you're interested email me at mikeseli@info-internet.net
Dali
Re: FS: ZE Block
Post by Dali »
can you find out how much to ship to williams lake bc postal code v2g2w5, thanks alot, email me unclesluggo@shaw.ca
1993 White gs klze.
Dali
Re: FS: ZE Block
Post by Dali »
can you also send me some pics, different angles and such, thanks.
1993 White gs klze.
Guest
Re: FS: ZE Block
Post by Guest »
hey can that be put on a stock 1.8L engine?
mikeseli
Re: FS: ZE Block
Post by mikeseli »
<blockquote><font size="1" face="Verdana, Arial">quote:</font><hr>Originally posted by magicfcb:
hey can that be put on a stock 1.8L engine?<hr></blockquote><p>Yes you can but you'll have a compression ratio of about 12 or 13:1 and you'll be restricing the engine passed 5000rpms due to the valve size of the K8 heads and the K8 IM runner size. The best thing to do is get KL-03 heads & IM from PGT/MX6/626 or Millenia heads and IM. The Millenia heads/IM will produce about 10hp more than the PGT/MX6/626.<p>You can get KL heads and KL IM for about $300Cdn from PT. <p>I have a KL-03 IM that is ported if you're interested.
