tire options question
eyezpinned
Post by eyezpinned »
ive been looking into getting wheels w/ a thicker sidewall to fill in my wheelwell better (thanks jesse...lol) right now i run motegi mr7s with 205/40/17 series tires. i guess my question is what wheel/tire combos are you guys with thicker sidewalls running? ive been thinking of lowering the car too, but i figured the wheels were do for an upgrade so would start there. also open to trade my motegis
93 rs: tokico struts & eibach springs, 15' rota gt3s, cf hood & gas lid, 2.5' exhaust w high-flow cat, tranny cooler, reupholstered seats, custom black interior, chrome miata handles, momo wheel & ebrake, spyder black projector lights w hid, altezzas, clear corners/sides, eclipse 8454 hu, diamond hex components w/ 3-way add-on & an re se 15' powered by 300/2v2 & 500/1 jl slash amps, corksport mazdaspeed bumper, euro mini sideskirts, fresh paint
ninjajim4
Re: tire options question
Post by ninjajim4 »
its the middle number... so you could move up to 45 and still be pretty accurate on the speedo. in truth, complete accuracy is right between 40 and 45
Ukrman
Post by Ukrman »
Heres tire size calculator, you can play around and figure out whats the best option for you.
http://www.miata.net/garage/tirecalc.html" onclick="window.open(this.href);return false;
Also, tirerack.com has alot of specifics about tires. You can compare performance in different conditions, weight of tires (varies alot between manufacturers). Also what I found kinda interesting is that even tires of the same size are different in size. What I mean by that is a 205/40R17 tire is not exact same size from different manufactures.
http://www.tirerack.com/indexA.jsp" onclick="window.open(this.href);return false;
92 Mazda MX3 GS
http://www.cardomain.com/id/ukrman" onclick="window.open(this.href);return false; - cardomain page
viewtopic.php?f=46&t=66481 - worklog
viewtopic.php?f=37&t=72099 - feedback
viewtopic.php?f=2&t=71757 - stuff for sale
http://s2.metaldamage.com/c.php?uid=159229" onclick="window.open(this.href);return false; - biggest waste of time
Post by wytbishop »
The overall diameter of the wheel is part of the calibration of the speedometer. Changing wheel diameter to fill the wheel well will alter the indicated speed on your speedo. For example, in exchanging your 205/40/17 tires for 205/45/17 you are actually changing from a tire with a wall height of 82mm to 92.5mm. It will increase the reading on your speedometer by about 3 - 4%.
Not bad, but not ideal either. I suggest sticking with the stock overall tire dimension and lowering the car to center the wheels in the wheel well. Getting a bigger tire is not the solution.
redmxlookin4turbo
Post by redmxlookin4turbo »
wytbishop wrote:The overall diameter of the wheel is part of the calibration of the speedometer. Changing wheel diameter to fill the wheel well will alter the indicated speed on your speedo. For example, in exchanging your 205/40/17 tires for 205/45/17 you are actually changing from a tire with a wall height of 82mm to 92.5mm. It will increase the reading on your speedometer by about 3 - 4%.
that calls for a bud light mr. tire diameter guy! :lol:
Post by wytbishop »
Ima math nerd...I can't help myself.
ninjajim4
Post by ninjajim4 »
you're right there's a ~3% difference, but youre going on the assumption that 205/40/17 is the equivelent of stock 15's. it's not. it's actually 1.7% too fast. 205/45/17 is 1.7% too slow. so there's not much of a trade off either way, and its ok to do. either way you won't have a 100% accurate speedo and it will be
+ or - the same percentage either way
Ukrman
Post by Ukrman »
yeah your 205/40/17 is smaller then the 205/55/15 so going with 205/45/17 woudn't make much of a difference at all
92 Mazda MX3 GS
Now I get it, size really does matter
eyezpinned
the whole speedometer being off by a few percent is non-issue. right now im just trying to address wheel well space. ive been looking into lowering the car too, but my erebuni bumper already hangs low so i dont know if id be able to close the wheel well space without putting my kit at risk.
ninjajim4
Post by ninjajim4 »
the point being is yes you could get bigger sidewalls and still be within the same range of accuracy you are now. i don't think you'll find anyone saying they use sizes other than whats been listed in this thread because typically people want their speedometers to show the speed they're actually going at...
but if all you care about is wheel well gap, then what are you asking the question for? go to the store and put a tire next to your car and see what fills the gap up. get 55's get 65's get whatever
Post by wytbishop »
^^^Anarchist.
ninjajim4
Post by ninjajim4 »
wytbishop wrote:^^^Anarchist.
free country lol...
onlytrueromeo
Post by onlytrueromeo »
More sidewall = worse handling
True for most applications. Don't just get a bigger sidewall, it will look stupid and will make the car handle odd.
eyezpinned
thats a good point... i dont want to sacrifice handling. some guy wants to trade me 16 inch slipstreams w/ 205/45/16 tires i might just do that and lower it a bit
Return to “Appearance”
