A little rust around the bottom of the doors, cracked windshield (At the top passenger side, out of the way)
It has a cold air intake installed.
It has a transmission cooler installed.
battery less than a year old
Breaks were done less than a year ago.
It has a nice radio in it, cd/mp3 player with a remote.
Stuff that is wrong with it:
Odometer and Speedometer do not work, needs a new cable. (The Tac works, and is easy to use as a speedometer)
It has an oil leak, mild.
I think the shocks/struts in the rear need to be replaced. Makes for a very bumpy ride when it's real cold outside.
It's Kelly Bluebook Private Party in "Fair" condition value is $1,485
It's never not ran, or not started on the first try, save for that
time it was super cold. I've bought a new battery since then though.
If you're interested, call me 517-775-4391
Images here http://digitalhaunt.net/car/" onclick="window.open(this.href);return false;
There are probably more around the forum, PM me or call if you want more photos.
Car is located in Lansing, MI
I'm moving to Chicago and won't need it there
