The car:
MX-3 RS, B6DE, Flowmaster 60 series.
The goal:
Make the car as quiet as possible.
Procedure:
I'm working from the hatch forward. Hatch has been covered fully by b-quiet ultimate, two layers, 100sq ft total. Door panels have also been covered fully with several layers, both inner frame and outer panels.
Difference between soundproofed doors vs. nonsoundproofed doors.
First two taps - soundproofed
second two taps - non soundproofed
(I have two MX-3's, so I can make a valid comparison)
doorpanel.mp3 - 0.18MB
That's pretty handy dandy, cuts down on the road noise a lot
However, there is a significant amount of resonance from the muffler, the way the MX-3 is designed. Fortunately this issue can be GREATLY reduced.
I've been contemplating how to do this for quite some time and I couldn't think of a good material to use.
I ended up walking down Lowes to find the answer. When i found the answer, after years of construction, I could have slapped myself.
Cellulose insulation.
Of COURSE! It's ground up paper! Just what I needed, a paper based insulation! Great R value, NO health concerns, lightweight and CHEAP!
Paid 8 bucks for a big pack of insulation. weighs less than 30 pounds. A bag will do the whole car. You can purchase cellulose insulation that is very fire retardant as well.
Where to put it?
There is about 5 inches gap between the outer panels and inner frame in the mid and rear portions of the car, with a convenient location to stuff it all in.
Shove that stuff in EVERYWHERE. If it won't stay, I stuffed a paper towel in the way so it wouldn't fall out... then continued stuffing.
Any gap between the outer body panel and the inner frame was stuffed.
This helps several issues. Resonance, road noise, moisture, and of course, heat/cold (if you have AC)
How effective is this?
Here is an audio clip of the difference by tapping on the insulated and non insulated panels
1st, 3rd, 5th tap, insulated panel
2nd, 4th, 6th tap, noninsulated panel.
Each consecutive tap is in generally the same section, so the 1st tap will be in the same section as the 2nd, 3rd in the same as 4th, 5th same as 6th.
quarterpanel.mp3 - 0.15MB
I unfortunately didn't think ahead of recording the resonance in the cabin before insulation... but however, I created a similar scenario. With the windows down, the resonance is extremely similar to the noninsulated car with the windows up.
Here is the graph of the sound clip
I traveled about 20mph, hitting right above 2k, where resonance is some of the greatest... and traveling slow enough so noise from the front end isn't affecting the noise of the resonance of the rear hatch area (where I have insulated)
Also at 20mph, wind noise is nonexistant.
See where the frequency cuts, is where I roll the windows up. It is a SIGNIFICANT DIFFERENCE in the cabin.
Let me repeat: Resonance of a closed (windows up) cabin without insulation is VERY similar to resonance of a open (windows down) cabin with insulation.
I personally believe (I know, I drive the dang car every day) the non-insulated closed cabin is still significantly louder than the insulated, open cabin, but I don't have results for this, so therefore I count my opinion as moot.
Here is the link for the audio file of the above graph:
insulate-test.mp3 - 0.91MB
It IS messy to put in, but for 8 bucks, a couple hours of work and 30 extra pounds, the results are so EXTREMELY worth it.
*UPDATE 8/01*
I did another experiment that proved worthwhile:
I wrapped the muffler in the exhaust heat wrap insulation that's supposed to go on your headers...
Well, it's not cured yet so the results will be better yet, but it's working VERY well.
I can also touch my flowmaster after a nice summer ride down the highway and not be burned.
This means I can spray that rubberized coating on the aluminum heat shield above the muffler. That thing resonates pretty bad when you tap it, so it's an experiment that opens possibilities to other modifications.
I am also following FowlJesse's mods and am now weatherstripping the car... till I ran out...
