Wheel Spacers..
Wheel Spacers..
My brother just gave me some red Rota Gt3 replica's and i wanted to add some wheel spacers, but i don't know what would be the correct size. I was hoping someone could help me out.
- hotsiit
Re: Wheel Spacers..
Some more info may get you the help your looking for.
Things like Size and Offset of the wheels, tire size, maybe what suspension your running (stock vs lowered)?
I bought a set (4 spacers) of H&R wheel spacershttp://www.optionimports.com/h-r-spacer-mazda.html (Link for reference, might be able to find cheaper), but I have not used them yet. They are only 5mm each spacer, so once i am ready to install the new rims, I will try without vs. with the spacers to see how I like it.
The offset can really change how the wheel will fit (inwards or outwards). Example, on my daily driver, I kind of went with a so-called "aggressive offset" of +53 from the stock +35
But I love the look.
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
1983 Mazda RX-7 GSL
1987 Jeep Comanche
Re: Wheel Spacers..
Go to corksport.com , better yet, here's the direct link :http://corksport.com/store/category/53g ... _misc.html
Scroll down to the bottom and take a look at the spacers there. And of course give them a call at 1.360.260.2675 to discuss anyother concerns you have about what you need to do.
Hope this helps.
Hope this helps.
If you fall, then get back up........Luck favors the prepared
