NOTE; It says "Custom" all over because I wrote this out for my Cardomain. You all know it's Home Depot, and Thrift store junk
- 2.5 liter KLDE engine
- true ram air with intake where the turn signal was.
- Customised K&N air filter with air tight box, and 4" hole, instead of 3, that tapers down to about 3".
- Custom 45 degree elbow from the Throttle body with about 3" diameter on the other side that connects to the air filter. It has a GM airflow sensor in it.
- Bored Throttle body 65mm with IAC deleted, and a coolant temp sensor in it's place. TB has the linkage turned upside down, so the Intake manifold clears the brake master cylinder.
- KLG4 Intake manifold from a 2002 Mazda 626 that has been ported, and has customised VRIS points.
- Phenolic IM spacers
- Ported and polished heads (with KLZE exhaust cams) that are port-matched to the IM, and Headers, and throat ported.
- 10:1 compression pistons on a balanced rotating assembly, and oversize main bearings.
- Ported Pacesetter long tube exhaust headers with the front flange deleted, and the tubes welded.
- 2.5" exhaust with only a FlowMaster HushPower muffler, catalytic converter, and one (Mandrel) bend to side exit.
- Solid motor mounts, and AWR Transmission mount.
- Unorthodox underdrive pulley
- Exedy clutch
- Customized engine torque strut made from one for a 240sx.
- MSD 6A box
- MSD Blaster2 coil
- MSD Super Conductor wires, 50 Ohms/ foot, shortened about 6 feet
- KLZE distributor
- Indexed plugs
- MegaSquirt and Spark engine management system.
- Custom catch can that lets nothing but clean air into the IM
- H&R springs on Gabriel struts (about 1.7" drop)
- Aluminum engine crossmember, and rear tie bar.
- Energy Suspension customized Poly bushings.
- Nyloil A-arm bushings
- Whiteline 22mm rear swaybar with Poly bushings, and custom (Wytbishop) solid endlinks.
- Aerospeed front strut tower brace
- MazdaSpeed rear strut tower brace
- Falken Azenis tires on 17" Mini rims
- Widened front bumper with covered grills for better aerodynamics.
- MazdaSpeed sideskirts
- Customised Civic projector headlights with Halos, and turn signals.
- customised ferrari style tail lights
- customised M3 style mirrors with turn signals
- Leather seats
- Alpine 9805 head unit, with detatchable face, CD, and Satellite radio.
- Boston accoustics 10 speaker system with 8'5" midbass, and custom kick panel boxes with tweets, and mids.
- Custom shift gate
- TWM short throw shifter with bearings instead of bushings
- shortened shift knob
- Alpine alarm with remote locks.
- Walbro 255l fuel pump
- Mazda 626 brake booster
- Stainless steel brake lines
- DynoJet Wideband O2 sensor/ controller, guage
- relocated battery to passenger side rear corner
- Fiberglass hatch with PloyCarbonate glass replacement
Waiting to be installed:
- MFactory helical Limited Slip Differential
- custom adjustable cam gears
To come:
- Lightweight wheels
I think I can tune 200WHP out of it, and I have finally achieved neutral handling
I bought lakersfan1's car, and want to give him credit for the work he's done. I'll first list the mods he did (to the best of my knowledge, as I am awaiting a list from him). Then I'll show what I've done, and update once in a while.
- Engine -
He completely rebuilt a ZE bottom end, and put on DE heads with ZE cams. It has an '02 626 IM, chipped DE ECU, balanced crank, .050 over main and rod bearings, chrome piston rings, Jap-spec 10:1 pistons, Jap-spec exhaust cams, main and rear seals. Just installed two years ago - 10,000 miles on the engine. Gets over 200 PSI compression on 5 cylinders, and 190 PSI on the 6th cylinder, and filled motor mounts. It has an Exedy organic clutch that grabs hard.
- Suspension -
He replaced all the bushings with ones from Energy Suspension (he has an FAQ in "Suspension"), and put in HR springs, and Gabriel struts, with new strut mounts and bearings. It has Nyloil solid front A-arm bushings.
It drives like it's on rails! I've driven Porsche's, sport Mercedes, and various fast cars (My dad is a german car mechanic), and this one handles better than all of them.
- Stereo -
It has an Alpine 9805 detatchable CD, MP3, XM stereo, with custom kickpanels with Boston Accoustics speakers in them, and 8” midbasses in the doors, and an Alpine alarm with remote locks.
In the corner to the left, you can see one of the custom speaker boxes. They sound incredible!
- Paint -
He was in the middle of painting it when I got it, so it has blue paint that is sanded down, awaiting a new coat.
I did the rest.
