This is bad...
Re: This is bad...
Thanks for the info Backfire, er I mean Nitefire. I'll call them. :)
nightfire
Re: This is bad...
Post by nightfire »
zzzoomx3 wrote:how much for the ZE trans? i'm being told that i need a DE trans for the longer gears - as opposed to the shorter K8 gears - but if a ZE trans would be better than both....
I'm not sure, but I think for an LSD transmission it could be anywhere from $500-1000 depending on condition.
I'm pretty sure my LSD is making a big difference because I'm absolutely killing all other FWD cars I race (off the mark). The only cars that have that have pulled ahead are a base C911 (though not by that much.. 1-2 car lengths to 100mph), a mustang GT and a 350Z. Aside from those I've been dusting GTIs, civics, a V6 mazda 6, bunch of ridiculously overpowered pickup trucks (some 5.7L ford), etc.
And it's amazing how hard it snaps out of corners.
- Gord
1996 MX-3 GS-ZE 2.5L 5spd
KLZE+LSD / Headers / KL02 VAF / Clutchmasters stage-I / Fidanza 9lb flywheel / Eibach Pro Kit / Tokico HPs / Urethane bushings & mounts / SSR Comp-C 16x7 / General Exclaim UHP 205/45R16 / Wilwood 13" brakes / Whiteline rear swaybar / Carputer / Software Crossover / Infinity components+subs / 41hz Tripath Amp9 / Trunk SLA batt / Keyless entry
zzzoomx3
Re: This is bad...
Post by zzzoomx3 »
sounds like its worth the money
