Help!! me rear speakers are not working
Car Stereo/Alarm Discussions
Cantary
Post by Cantary »
I need help I have a 94 Mx-3 and I had a anitfreeze hose just break under my disturburtor and killed it. I have just replaced the hose and the disturbortor but now my subwoofer is barely wokring and my speakers in the back are not working. they work just fine in front I tried up there and in each others spot. I looked at all the wiring and it is perfectly fine there too. I am lost to what to do I have had this set in my car working just fine for five months and now it doesn't work. Also I have no horse power what so ever my alternate is brand new and just fine I had it tested. That also happened after My hose blew. My car has problems and I like to get them fixed so can you please post back to me on what to do or what to try.
Re: Help!! me rear speakers are not working
If you replaced your Disty did you check the timing?
umcamara
Post by umcamara »
Your rear speakers are likely just blown. If you want to test them you can disconnect the two leads from each speaker, and probe the two leads (on the speaker) simultaneously with a 9 volt battery for a very short period of time, a fraction of a second. If you hear a static pop out of the speaker, it still works to some degree, and should produce sound.
As Daninski said, you can't just remove a distributor and install another one, without timing it, and expect everything to be okay. That's likely why you have no power. The stereo situation is probably unrelated.
'96 Silver Stone Metallic MTX RS
'98 BMW 328is M-Tech
Feedback Thread
Return to “Car Stereo/Alarm”
