Rear Wiper Arm
- Hoodzy
Rear Wiper Arm
Some d--- broke off my rear wiper arm
I tried to get one off a 93 and it doesnt use the simple nut which u just loosen from on top to get it off.. there are the 2 smaller nuts underneath that i loosenedbut seems to have no effect
any ideas how to get a rear wiper arm off a 93
thanks
thanks
1995 Creek Mica Blue GS
Re: Rear Wiper Arm
http://www.autozone.com/az/cds/en_us/09 ... oPages.htm" onclick="window.open(this.href);return false;
Auto zone has a lot of good info, not sure if this will help.
Re: Rear Wiper Arm
maybe also look in the online manuals?
Re: Rear Wiper Arm
I could never figure it out myself , but be careful , when I tried to get on in the yard the whole window came with it and almost took out my arm ..
93 Kandy Tangerine Mx3 GS-DE
02 Subaru Impreza OBS
& Lots of Toys to haul
Re: Rear Wiper Arm
IIRC correctly, it actually does come off with jus that one nut at the top. i did once and it was a real b*tch to do... i think i tried it again and it didn't work. i recall using a flat head or something to kinda pry it up off the post
Re: Rear Wiper Arm
A shaped charge of C-4 might do the job too.
Re: Rear Wiper Arm
wow .. you guys are having that much trouble taking your rear wiper arms off? .. i took mine off the other day .. it was the small nut on the top of the arm ... then i just pushed down on the arm its self .. about a inch away from the nut .. then just lifted it off .. hope this helps!!
Re: Rear Wiper Arm
Best Idea yet !!Daninski wrote:A shaped charge of C-4 might do the job too.
- Kirk95gs
Re: Rear Wiper Arm
I removed my wiper a couple years ago. One nut on the back. If you need to replace the hole unit you have to remove the trim under the hatch. IIRC there is three screws holding a cover over the motor. Disconect the harness, Couple bolts holding it to the hatch. Remove the one nut on the arm from the topside. Then pull the stuff apart.
Re: Rear Wiper Arm
Here's something i wanted to do for a very long time - i want the rear wiper to stay in the horizontal position when off instead of sticking up in a vertical position - i dont know why but i just hate this wiper sticking up there (and casting weird shadows at night). I will open up the assembly one day and see if it can be done ......
