K&N air fliter
- bp_turbo94
K&N air fliter
i looked to find the horse pow gain for the gs V6 by useing a k&n air fliter , but all found was the hp gain for a mx5, it was like 3.2 i think but does any body have a idea about how much it will give you?
- solo_ryder
Re: K&N air fliter
HEHEHE, no-one I think knows the exact number sir. I don't think it will make that much of a difference, maybe 3hp and an improvement on the butt dyno. Its all about the sound you get from the intake
- mx3autozam
Re: K&N air fliter
There is definitly a differene. The engine is getting more air beacsue of the design of thee filter and depending on where you put the filter you will be getting cooler air. It maakes a big difference on the butt dyno and changes the power band slightgly. The true gain if you put it on a dyno is around 2-3hp. It definitly adds a nice sound wwhich is what most people get them for. Good Luck!!!!
93 Mazda MX3 KLZE Turbo
- mitmaks
Re: K&N air fliter
if you guys want to chip in $50 I can have K&N dynoed on k8 mx3 (mine) lol that was we all know for sure
Smith18
Re: K&N air fliter
I think hes talking about a drop in filter as apposed to a Cold air intake. You'll notice alot better throttle response when pushing on the peddle thats about it... there is no real HP or TQ gains.
1993 Mazda MX-3 GS, V6 KLZE 2.5L, CenterForce Duel Friction Clutch, Nylon Shifter Bushings (from Imazda.com), Integra Cold Air Intake, Millenia Intake Manifold, Indigo Gauges, Pacesetter Header->Resonator->2.5" piping->Dynomax Muffler, VSX Front and back bumpers from FX Designs, AWR Front and back Motor Mounts.
- fowljesse
Re: K&N air fliter
There is about <1-2 HP gain, depending what you're starting with. The reason for getting K&N is: As it gets used, they keep better flow longer than paper, and you never have to replace it. You can choose to keep CFM up, by washing it. I wash mine about every 2,000 miles.
- tehbrookzorz
Re: K&N air fliter
Yeah, we get the shaft. K&N filters make 40-50hp on Hondas, but for our Mazdas, only 1-2hp.
Cody
Re: K&N air fliter
tehbrookzorz wrote:Yeah, we get the shaft. K&N filters make 40-50hp on Hondas, but for our Mazdas, only 1-2hp.
hahahahahahahha even if you boost it you would be preaty lucky to be able to get that much from a honda lol
Re: K&N air fliter
I had all my mild modifications done at the same time, so I don't know what if any contribution K&N had to the overall effect. I think headers and lightweight flywheel had the most to do with it.
