I GOT A MX-3 4CYL AND CAN I SWAP IT WITH A KL-ZE OR WITH WAT
Mx3_project08
I GOT THIS CAR 4 800 NOT BAD BUT DONT KNOW WATH KIND OF SWAP I SHOULD DO???
AND I WAZ INTO HONDA BUT I GOT THIS CAR AND DRIFTS NICE WELL IN THE RAIN...LOL BUT REALLY WATH I GOT TO DO tell me
- onlytrueromeo
- ElectricEnergy
Re: I GOT A MX-3 4CYL AND CAN I SWAP IT WITH A KL-ZE OR WITH WAT
Holy Crap,
It sounds like your into drifting. I've had a lot of experience in this area, let me suggest a few simple upgrades.
First off, the 4cyl is plenty of power for drifting, you might consider a nice big scoop on the hood to get just a little more air into there. I've seen some nice ones at Canadian tire. Also cut off your exhaust at the headers and you'll be good to go.
Front wheel drive cars face a few challenges in the drift scene since they can't actually get the back wheels spinning. The easiest way to get around this is to remove the back tires. Thats right, just take them off. Metal doesn't grip concrete very well and will enable to you slide around just like DK from Tokyo Drift.
Seriously though, read the FAQs on the forum, they should answer all your questions. I'll point you in the right direction by saying if you want to do an engine swap on your 4 cylinder, your probably interested in the BP-T.
David
David
- Custommx3
- Site Administrator
Drifting is for RWD.
OH AND TURN OFF YOUR CAPS LOCK CAUSE THIS IS ANNOYING THANKS
ill second that custom
94' KF-ZE, 2 Tone black and gray, Projectors and altezzas ( black ), CAI, moulded mazdaspeed mini sides. Raised spoiler.
I'm goin outside to take my back wheels off RIGHT NOW!!! This is gonna be frickin awesome!!!
yes, the KL-ZE should drop right in. It should give you about 250 whp, and if you boost it, you'll get at least 375. That should be plenty of power to get that rear end sliding around
'94 GS-DE
- atlantamx3
hahahaha- Not sure who that n00b is ^^^ , but he is wrong. KL-ZE is good for 160-170 WHP N/A, not 250.the_anj wrote:yes, the KL-ZE should drop right in. It should give you about 250 whp, and if you boost it, you'll get at least 375. That should be plenty of power to get that rear end sliding around
I think he was joking...
I tried the rear wheel drift mod and it turns out that ElectricEnergy was joking too...anyone got a set of rear rotors, calipers, pads, TTL's and bumper for sale cheap???
It did drift really nice tho'
it was a joke...I figured if he wants a serious answer, there's a search function.
as for drifting, it might be kind of cool to rig up some sort of metal skis that would let the back end slide around without having to wreck a set of rims
'94 GS-DE
if you want to go drifting in your mx-3 you can do a simple mod that lasts for a very short session.
1. Insert piece of wood under each rear tire.
2. Pull e-brake up
3. DRIFT!!!
2. Pull e-brake up
3. DRIFT!!!
NO NO NO all you have to do to drift in a FWD car is drive in reverse. haha
lol
lol
- Custommx3
My friend paul and I used particle board (safer and legal).
Roll your rear tires on the boards, ebrake it... drift
when the boards are gone, release your ebrake, roll off the boards.
SmoothMX3
Down here, we call that panning. Get in a big parking lot. roll onto cooking pans on each tire. Pull e-brake. gun it and turn. haha
93 MX-3 2.5 KLZE - KL101 \\ H&R Springs \\ Short Shifter \\ 17" ADR Rims \\ 205/40/R17 Namkang Tires \\ Millenia Manifold \\ Rockford Amp \\ Rockford 12" Sub \\
--- K8 was my gateway drug.
I've heard of using a couple of those plastic trays from restaurants
'94 GS-DE
