mx3 13.5 @109
- 93MX3KLZE-T
mx3 13.5 @109
Hey guys this is my 93 mx-3 gs with a klze and t304e turbo.  I was running 5 psi.  http://youtube.com/watch?v=621RyTKPj5s" onclick="window.open(this.href);return false;
Jeremy
							Jeremy
93 MX-3 GS, KL-ZE, T304E ***SOLD***
221.9 whp 219.0 wtq @ 5 psi untuned
13.4 @ 108 mph
13.4 @ 108 mph
Re: mx3 13.5 @109
impressive sir
Re: mx3 13.5 @109
nice man
i say this summer some time we meet up (hopefully dropfest) and show everyone in Wisconsin what mx3's r all about
http://www.cardomain.com/ride/2433610" onclick="window.open(this.href);return false;
mx-3 Kl Turbo (Weekend/show car)
95 talon tsi awd (Daily Driver For Sale 6,000 or Trade for a Mx
1989 Cbr600 (StreetFighter/Stunt Bike)
1967 Winnebago Motor Home (Pimped out Party Bus a friend and I went in halfs on)
1972 gremlin X Turbo Diesel
 , 1999 VR4 Fathers Cars that i end up working on and drving alot
				smallblockman69
Re: mx3 13.5 @109
wow that is awesome i keep up the good work!
						- mx3autozam
Re: mx3 13.5 @109
I like that...109mph trap is impressive. That car can definitly break 12's
							93 Mazda MX3 KLZE Turbo
						- 93MX3KLZE-T
Re: mx3 13.5 @109
Thank you. The car could break into the 12's if I could get traction. If I turn up the boost I just spin the tires all the way down the track until fourth gear.mx3autozam wrote:I like that...109mph trap is impressive. That car can definitly break 12's
Jeremy
13.4 @ 108 mph
13.4 @ 108 mph
				2RotorsNaDream
Re: mx3 13.5 @109
Thats the problem with FWD it never gets traction. Get a pair of slicks and a new suspension and bushings etc and go out there. I dont know if it will crack 12s with those whp numbers though but itll be damn close if it doesnt break it. My car stock is 215whp and runs 13.5 and it doesnt weigh much more than a V6 MX-3.
1993 Mazda RX-7 Touring Edition Innocent Blue Mica- Not stock...1993 Teal MX-3 GS- KLZE and other goodies. RIP
- hppwdn
Re: mx3 13.5 @109
Turn your wheel back and forth while you're doing your burnout. It's gets both wheels to spin. Make sure you have your ebrake pulled as well.93MX3KLZE-T wrote: and oh yeah it's a one wheel wonder.
92 MX3 Turbo  ($100 junkyard KLG4) 11.904 @ 124.3mph, 14psi, DOT approved Hoosier drags, pump gas.
- mx3autozam
Re: mx3 13.5 @109
^^^^^^^^^^^^^That works too, but an LSD works so much better, and will help with traction as well.
						- mitmaks
Re: mx3 13.5 @109
good time
							Magnum s/s lines, strut bars, carbon fiber bezel, indiglow gauge, Sony Xplod, inverted c/f hood, SRD lower tie bar '93 GS SE  '95 Cobra SVT #2722 '68 Charger R/T 440
- fowljesse
Re: mx3 13.5 @109
Thanks hppdwn. I didn't know that. This is my 1st FWD that I've done anything with.
So, both tires being sticky.. Doesn't just the right one spin, anyway, if it's going straight?
						- XxantwawnxX
Re: mx3 13.5 @109
yea i know all about wheelspin.....i got 13.3 at 110 with pretty much the same setup...but i think my car is lighter and i had ok struts. but i spin first and second haha and still got a 13.3.
still need to dyno tune mine haha. but great time!
Re: mx3 13.5 @109
Well done - that's a hell of a trap at only 5psi.  Focus on your short times and the 12s will come.  More power right now will just do you bad, more traction is where you want to be at.
							'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
'93 Ford Probe GT - a few mods... 10.24 @ 139.5 mph [20 psi] - 545 whp, 490 wtq @ 21psi
1997 Ford Probe GTS (Hybrid) - RWD Conversion - Build Thread
- DimaK
Re: mx3 13.5 @109
[quote="mx3autozam"]I like that...109mph trap is impressive. That car can definitly break 12's[/quote]
i donno man, yours ran 14.4 is it? with just the ze no turbo.....after you put the cams in.....i can see i do it 13.5
