Hi!
I just had a deck installed. Now everytime I turn the deck on, or turn the car off, there is a loud "clunk" sound through my speakers. Also, when the guy hooked up my remote wire, the bass is fine until I turn it up loud, then it is a constant "BOOOOMMMM" that doesnt stop unless I disconnect the remote wire or turn off the deck.
The old deck wasnt doing any of this! It worked perfect! I'm just wondering what this could possibly be! The "new" deck also worked perfect in the car it came out of.
Any thoughts? I'd appreciate it!
THANKS
help! not sure what this means!
- TREVO123
Re: help! not sure what this means!
He could have hooked some wires up wrong, Check all RCA's and make sure they are correct cuz they will do the boom thing thru ur subs if there wrong.
I'm wondering if it's not grounded well either...
- TREVO123
that could be it as well.
- 2fazed
If you can, take the deck out as much as possible, then turn it on and see if it pops. I've had this on a few decks. I think one of the ground wires, when they shove the deck in, gets pinched, so it doesn't ground good. If all the harness wires are good, and it just happens to your subs, you can get a rca filter($15) that will fix the extended noise.
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
06 Mazdaspeed6 2.3T
93 626 ES 2.5
92 Mx-3 RS 1.6
93 Mx-3 GS 2.5
93 Mx-3 RS 1.6
- sk8erdude802
I vote take it back to where you got it installed. I mean I assume you paid money to have them install it...sounds like they messed something up.
Thats my .02
Steve-O
Thats my .02
Steve-O
93' MX-3 GS SE ZE - Sold to Acheron1502! SOLD!!!
93' MX-3 GS SE - R.I.P. K8 with Integra CAI, HEI mod, Koni inserts with H&R's,drift kit, Kicker KX400.1 and KX200.2 amps, 2 kicker 12s, set of 6x9's. Custom trunk enclosure
MyFeedBackThread
^^^^^ Click on image for my work log ^^^^^
MyFeedBackThread
- CarolinaCartel
Check your ground!! If thats not it then make sure to didn't run a screw or something thru your rca somewhere. If that not it, try running a rca from your home stereo or another HV to your amp. If you have the same problem then its your input on your and if not there is a problem with your output on your HV.
1993 Mx-3 Gs
09 Setup
Headunit: Pioneer DEH-P80MP w/CD-IB100II & 60 gb Ipod
Speaker: 2 pr MB Quart ESA216 6.5" COMPONENT
Subs: 2 Sundown 15" Nightshades
Highs amp: Sundown SAX-125.2
Sub amp: Sundown SAZ-3000D
Electrical: All 1/0 KnuKonceptz Wire Power/Ground, Big 3, 8Ga Speaker Wire, KnuKonceptz Karma RCA's
Dampening: 120sqft 80Mil Thick Sound Destroyer Mat
Goal: 150 DB 149.9 Street Bass
09 Setup
alright thanks everyone for the help.
It must have been the actual deck or wire connector, because I took it out and put in my old deck and everything is working fine. But thanks again for the replies!
