where do I get the adapter to run an adjustable fuel pressure regulator?
you know, the thing so I can bolt up the regulator, or hook up a fuel line up to the factory fuel rails.
thanks
7
Adjustable fuel pressure regulator.
- se7en
1992 mx-3 GS-T, 10-12psi, T3/t4 hybrid, Turbosmart WG, AFPR, SSAC TURBO pipes, MSD Blaster coil, K&N, AEM W/B, MSnS(full standalone), 225Whp street tuned(10psi), 245Whp (12psi)(300bhp!!!)
1992 Fairlady Z(JDM RHD) 2+2 TT black(done!)700whp+
Don't Click Here! Trust me,Time waster!
Bochek
Re: Adjustable fuel pressure regulator.
If i understand you correctly you are looking for an adapter to replace your factory FPR with a hose, so you can connect it with an AFPR.
If that is correct then you should pay a visit to MBXMotorsports, they have exactly what you are looking for.
http://www.mbxmotorsports.net/store.htm" onclick="window.open(this.href);return false;
Top Right Corner.
Hope this helps,
-Bochek
Top Right Corner.
Hope this helps,
-Bochek
Adam Bochek's 93 1.6L SOHC http://www.bochek.ca/car.gif
- se7en
ah, jeez, I can make one of those at my shop no problem! that's what I will do.
thanks for the link to the pic!
7
7
Bochek
i can help you out with a predrawn image with dimensions if you have autodesk inventor or equivilant.
