Blow Check engine light
Lynch
Post by Lynch »
Hey everyone. I've got a 93 Mx-3, 24 valve, DOHC.. which i purchased a month ago, and i've been trying to get it to run properly ever since. As i have read on many posts this car has idle issues and i'm having the same problem. I've changed the distributor, plugs, IAC valve, checked for vaccum leaks and i'm still having the issue but only when the engine gets warm.
I have one problem, i went to check for codes on my system when i realized my check engine light is blown. Is there another way to check for them, because i don't have the time right now to take the dash apart to change a light bulb.
Your help would be appreciated
Lynch
1993 MX-3 1.8, 5sp, Citrus Orange
umcamara
Post by umcamara »
Instead of jumping T.EN and Ground in the diagnostic connector, use an L.E.D. and jump I believe F.EN. and ground. Then follow the same ignition procedure.
I am not 100% sure that the pin is F.E.N.
'96 Silver Stone Metallic MTX RS
'98 BMW 328is M-Tech
Feedback Thread
Dark_Rider2k3
Post by Dark_Rider2k3 »
On my 4cyl, I did an idle adjustment, and now when i'm stopped @ red lights, it idles at about 700-900 RPM's, and there is no more vibrations throughout the car.
I also (which helped), ran some seafoam through the car, and it cleared up my fuel injectors (I had one that was really bad), so idk if that helps ya, but it helped me
shameem
Re: Blow Check engine light
Post by shameem »
Lynch wrote:Hey everyone. I've got a 93 Mx-3, 24 valve, DOHC.. which i purchased a month ago, and i've been trying to get it to run properly ever since. As i have read on many posts this car has idle issues and i'm having the same problem. I've changed the distributor, plugs, IAC valve, checked for vaccum leaks and i'm still having the issue but only when the engine gets warm.
Lynch
Jump TEN->GND and connect a test light between FEN and B+ . The test light will act like the CEL.
it's really not that difficult to take out the instrument cluster... :roll:
Lynch
Post by Lynch »
I don't have a problem taking it out, my problem is time and weather. Seeing that we just got snow and freezing rain, and i dont' have a garage... the project car might take some time :(
BTW thanks for your responses, i'll keep you updated on my progress.
Raven95150
Post by Raven95150 »
A guy at my work has a Snap-On Ethos scanner...thats what I used on mine. It tells you the codes and what they mean right on the screen. It's really amazing what the thing will do on OBD-II cars. If you have a couple grand burning a hole in your pocket, go and get one. Otherwise, I would just change the bulb.
No more MX-3
2005 Hyundai Tiburon GT
95 F-150...6" lift, 35" tires
umcamara
Post by umcamara »
Raven95150 wrote:A guy at my work has a Snap-On Ethos scanner...thats what I used on mine. It tells you the codes and what they mean right on the screen. It's really amazing what the thing will do on OBD-II cars. If you have a couple grand burning a hole in your pocket, go and get one. Otherwise, I would just change the bulb.
His cars a '93 = No OBD-II
My car's even a '96, and I'm still not convinced it's OBD-II. I've got the connector, but can't pull anything but "error" with a scan-tool. Jumping T.EN and Ground won't give me the code either. Maybe I've got nothing. :cry:
Feedback Thread
Raven95150
Mine is also a 93 so its not OBD-II either, I was just adding that in there. That scanner has a data cable with like 20 different adapters to work on just about any car.
No more MX-3
Lynch
Post by Lynch »
Well, I fixed my problem with the car. I hate to say it, but it was a stupid vaccum leak. Ordered a new cold air intake from ebay, the one with the two connectors on it, for the vaccum lines. Fixed my problem completely. The old setup was done poorly, and didn't have those connectors.
So to sum it up, lots of time and money wasted, to find out it was a vaccum leak. Frustrating as hell, yet satisfying knowing it now runs properly. :x :D
Thanks again for the help all
