turbo 2.0 to a 1.6
tazman734
turbo 2.0 to a 1.6
will the turbo system from a 2.2 mx3 fit to a 1.6 dohc manly the exhaust manifold ? or is there a way to fix it so it works ?
tazman734
- Limegreen mx-3
are you on crack HELL NO it work..
common sense 2 very different design motor whould even think the turbo manifold form the F2T would really bolt up to the 1.6 dohc ummm no
but i'll point u in the rite direction even though i know u probly haven't even taken the tyme to search for it..
the turbo system from a 88 323GTX or capri xr2 the have a 1.6 dohc turbo and well the turbo manifold from the B6T will bolt up to ur dohc,,
- monty73741
the corksport mani is the 323 b6t manifold...it takes anyIHI turbozCat wrote:Corksport sells a mani to adapt the F2T turbo to the MX. KTHXBYE.
Jason Danaher
Please Help Support MX-3.com
osargeant
The 323 GTX manifold doesnt take any IHI turbo, to be more specific it bolts on to both the IHI VJ11 (MX6/Probe) and IHI VJ14 (323GTX) turbos.
You cant bolt up say a Subaru IHI VF series to it for instance.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
