Did any RS's come with these? Because I notice mine is not there...unless somebody just took it out which seems odd
[WTB] Parking Brake Switch
Lookwuticando
You know, the little switch that goes under the brake handle that shows when it's on or not by the light on the dash...
92 MX-3 RS
Yes, it came in the rs and every other car with a hand ebrake..
its not really a switch... its just a piece of plastic with a spring in it so when you pull the ebrake, it grounds out the circuite, which is completing the circuite for that light in your dash.... look for the wire there.... if you take that wire and touch it to metal somewhere, it will ground out the wire and your dash light will come on...
Lookwuticando
It's something that when the brake lever reaches the position at the bottom it causes the light to go off---and there's nothing there. Just a empty place where some type of disconnect would be fastened. And an unused empty socket where it would be plugged in, tested the wires and they go to the light in the dash.
Anyway, still need. C'mon, I know it's just a silly little piece, but somebody sell me one please...
92 MX-3 RS
m90daytona
m90daytona
