[EBAY] Turbo kit k8, de ,ze
http://cgi.ebay.com/ebaymotors/Ford-Pro ... dZViewItem
I got one and waiting on it.. apparently this guy has like 14 of these.
-hec
Ill tell u first hand its gona take quite o bit of customizing to make that kit work
http://profile.myspace.com/index.cfm?fu ... d=77496445
My Car: Mazda MX-3 v6
14.5 @97mph
2.328 60ft....still more room for improvement
Only 165whp
Now boosted & New #'s to come
14.5 @97mph
Only 165whp
yah, just shortening of the big pipe and the typical cross member mod.
-hec
hgallegos915 wrote:yah, just shortening of the big pipe and the typical cross member mod.
ya i wish it was that simple
14.5 @97mph
Only 165whp
14.5 @97mph
Only 165whp
Ask andy, he is living proof that you dont have to chop, ill be second proof of that
-hec
I will let you in on a secret right off the bat!! DO NOT USE THOSE T3/T4 Generic TURBOS FOR $179 ON EBAY THAT COME WITH THE KIT!!! They are glued together where the hot side meets the cold side!!! guys on probe talk are having cracking issues since it gets sooo hot and makes the glue loosen in result making the turbo fall apart!
- hppwdn
The first batches of those turbos that came out did do that. But the recent ones aren't causing any problems. I've put them on a few cars for people, some of which run them hard all the time, and they haven't failed or shown signs of it.colinsmx3 wrote:I will let you in on a secret right off the bat!! DO NOT USE THOSE T3/T4 Generic TURBOS FOR $179 ON EBAY THAT COME WITH THE KIT!!! They are glued together where the hot side meets the cold side!!! guys on probe talk are having cracking issues since it gets sooo hot and makes the glue loosen in result making the turbo fall apart!
Probably the same situation like the first generation of Cosmo regulators that were always failing. It gave them a bad rep, but all the ones after that first batch lasted for years and years with no problems.
