Poly Engine mount inserts
- PATDIESEL
You can buy the liquid urethane a McMaster-Carr. I think it is about 40 bucks and will be enough to fill all your mounts. FYI
- ccreech
I can never find it on McMaster-Carrs website anymore. The manufacturer that we used was Forsch Polymers Corp. In case you want to use them:
http://www.forschpolymer.com/
Edit...Found it. go to http://www.McMaster.com and in the search field enter the part number 8644K11
timpronk
Laugh it up, I have hockey pucks in my front engine mount for a couple of years now. Works great as far as I can tell!
Drill a hole through the center, mount the little steel sleeve from the orig insert (If I remember correctyl), carve around the edge of the puck so it fits in the mount, and pound it in there. Still takes awhile, but its quicker than the poly method and so far has had no bad effects.
92 MX-3 GS 2.5 KLZE
14.385 @ 98.21
14.385 @ 98.21
- mx3autozam
lol...i like that oneccreech wrote:I am from Georgia...and the NHL won't ship Hockey pucks over the border last time I heard. (Something about not enough ice...or already missing teeth...I dunno!)
more on topic imine are gilled with urethane window weld and are holding up fine. i did them when i had the motor out of the car and let them dry for a few days. I wanna buy new mounts and fill them with the real stuff(Liquid Urethane) the hockey puck idea is an olschool truck surprised it wasn't mentoned in the begiuniing of the thread.
93 Mazda MX3 KLZE Turbo
I'm curious ... assuming that those of you who have added the 2-part urethane, properly prepped the existing mount well (cleaned any dirt/oil from the rubber, and roughed it up a little bit with sandpaper) the question is this: has the urethane stayed intact? Or has it crumbled or de-laminated from the original mount/rubber over time??ccreech wrote:The manufacturer that we used was Forsch Polymers Corp. http://www.forschpolymer.com/
