KLZE in Kamloops, BC
Anybody running a ZE in Kamloops. I have installed engine in my 92 MX3 and am waiting for ECU. Would like to take a look at your setup.
- solo_ryder
- solo_ryder
I was the guy in Kamloops with a KLZE MX3. I wasnt the first person in Kamloops to run a KLZE however, there is a Probe GT turbocharged with a KLZE in Kamloops. I was the first MX3 KLZE thoughsolo_ryder wrote:Hey, there was a guy in loops, but he has sold the car. I am in vernon and the sole ZE'er around lol. There are some other guys, but they do not go on the board.
When I come into Kamloops next I'd like to check out your car. Are you on Intencity?
93 GS, KLZE, KL31 ECU, Centerforce Stg 3 Clutch, 2.25" Exhaust w/Flowmaster muffler, OBX Headers, Pheno Spacers, Front & rear X-drilled/slotted Rotors, KVR pads, SS brake & clutch lines, Ractive Filter, H&R Springs, Tokico Blue Struts, 8mm Accel Wires, MSD 6A w/ Blaster 2 Coil, HVAC Indiglo Panel. *Sold*
06 Eclipse GT *Sold*
08 Evo X GSR *Current*
I have installed the KLZE with MS8 curved manifold, KL31 ecu, new disty,timing belt, phenolic spacers, water pump and disconnected EGR and solenoids. Having a problem with fuel injectors. Have good spark but do not seem to be getting fuel. Fuel pressure is good but injector voltage seems low and not firing. Cleaned up ground wires, checked timing, spark etc. Suspect bad fuel rail or wiring problem. Anyone out there have similar problem?
- solo_ryder
Sounds like a pretty good set up.JMac wrote:I have installed the KLZE with MS8 curved manifold, KL31 ecu, new disty,timing belt, phenolic spacers, water pump and disconnected EGR and solenoids. Having a problem with fuel injectors. Have good spark but do not seem to be getting fuel. Fuel pressure is good but injector voltage seems low and not firing. Cleaned up ground wires, checked timing, spark etc. Suspect bad fuel rail or wiring problem. Anyone out there have similar problem?
I also had the MS8 Intake and the same ECU. I disconnected and removed all the EGR from my car, charcoal cannister.
Would definitely like to see your car.
- solo_ryder
Found the problem. Partial ground inside plug connection going up to heat sink near firewall. Repaired connection and motor is running like a top. Had been checking all ground connections and noticed small burn mark on plug connection. This partial grounding would not let ECU fire injectors. Disconnected all EGR plugs, removed two solenoids, EGR and plugged EGR connection to exhaust manifold. Set up timing to 10 degrees and the idle to 750 rpm.
Zoom Zoom, this engine runs smooth and pull allot harder than the stock 1.8. The difference is outstanding. Will be taking car up north (St. John)for a few months so if anyone sees the bright yellow MX3, take a look.
- wyldside
Just an FYI but the MS8 intake is the Straight neck intake, not curved. You probably have an intake from a Xedos9, Eunos800, or Millenia. Those are all curved neck intakes with square runners.
James Gosteli
X-Prez of MX-West
1992 Seal-Gray MX-3 GSR-ZE (KLZE 2.5L V6)
1992 White MX-3 GSR-ZE (KLZE 2.5L V6)
Worklog (Parting out)
1993 Blaze Red MX-3 GS - RIP
X-Prez of MX-West
