YAY !!!!! car back to being boosted.
- XxantwawnxX
Well turns out my seal was not blew, i guess i had a kink in the drain line. I totally revamped the drain sytem and now she is leaking oil no more! I got my second car (ranger) so now you might be able to finally see some track times on my ZE-T. cant wait. To bad its winter time...
- papa roached
haha, my second ride is a ranger too
- XxantwawnxX
yea got it for 800 bucks : ). Ill be getting my headers and real hot pipes soon(not my ghetto fab ones ) and a 9 pound flywheel, woohoo!
- papa roached
funny how similar things go on between our cars and stuff
