Help! Need Pulley Part#
I had a pulley changed on my ZE recently and told the garage to use 2.5L '95 MX-6 parts for my car and the pulley they installed does not fit at all. Can anyone help me out with the part number I need. I can't make out any part numbers on the broken pulley except for a 9V on the metal and NSK 6203DULX on the inner rubber part. I'm not very mechanically inclined so I can't say which pulley it is other than it's from the left side of the engine and had to do with the alternator because when the pulley broke I lost all power in my car (after about 10 mins of the battery draining).
							'96 MX-3, KLZE, ZE Curve Neck Intake, KL68 TB, K8 ECU, CAI, KL-02 VAF.
				hgallegos915
thats strange.. my k8 pulley fit my klze..
							-hec
- PATDIESEL
What does the pulley attach to? The alt, the crank, the idler pulley??? We have to know which one to be able to give a part number. Actually you can find which it is and the part number at the same time by finding a pic of it in the online shop manual on MX-3.coms front page. Look on the left side under the "Tech" section.
if my crude math is correct 8 cm is 3.1 inches
the alternator pulley is under 2''
the p/s pulley is over 4"
main craink pulley is 6-8"
ac pulley 5"
so that leaves the tensioner pulleys
both belts have one they both are smooth or non groved
is this is the needed part i would recomend replacing the sealed bearing its self. instead of the whole pulley. the bearing is a bca 603 i think.
if you want i will check it out and confirm the part number. the bearing is used in tons of other pullies any part store can sell a idler pulley for a doge mini van and you can knock it out of that pulley and pressit in to your pulley.
ac pulley 5"
JUDGE ME ALL YOU WANT
93 gs, klde swap, kl trans, strait 2.5'' ehaust, euro front bumper, cold air intake, hei ign ,50 shot &
9.60s n the 8th mile so far 8.50s sprayn now
150 shot
150 shot
- Yoda
I looked through my box of parts pulled from various KL-ZE, KL-DE, K8 and a KF. Of the 7 or 8 tensioners and idler pulleies I looked at they all have the same alternator belt tensioner bracket double threaded adjustment screw and idler pulley. The only thing I can see is that your mechanic lost the hard plastic spacer that goes between the pulley and bracket.Overclock wrote:Yes the pulley is smooth all around and I definitely need to change the whole pulley and not just the bearing.
