cjthor wrote:nothing other than making the floor flat back there. You MIGHT lose 2-3 pounds.
Actually he may loose more that just a few pounds. For example were Illapino lives. If he were to checks with the DMV in BC and ICBC, he would find that in BC he will need to have the car inspected after making an alteration to the "chassis" of the car. I forward a link of the photo to a contacts I have out west and received that following info from the BC motor vehicle act.
"Rebuilt, altered or constructed vehicles (including kit vehicles) require a structural inspection along with the mechanical safety inspection at a designated B.C. inspection facility before they can be re-registered, licensed and insured."
The comments made about the quality of the weld in the picture were not very positive. There is not sign of any structural reenforcement added to take the place of the spare tire tub which makes up a majority of the strength to the rear end of the car. And there is not even any bead rolls added to the flat sheetmetal that would add some additional structural rigidity back to the rear end.
All this basically means that the people I was communicating with would not allow have allowed this car back on the road if it had come it to them in at least 4 provinces in Canada. Technically by the letter of the law in BC in until the car is structurally inspected his registration and insurance are suspended from the date the alteration is made until it passes inspection. In Alberta and Quebec the car a scrap order could be issues.
So there is a lot more to loose if you don't inform yourself before make a modification where you are altering a unibody chassis.
