here is a pic of my latest interior mod, i call it the "lack of" mod
boy the back end likes to slide around corners now, took everything from the doors back and the carpet, still not done though, a little bit more is coming out and different seats are going in and with losing all that and the stereo stuff i can feel a good change in the go power now to just get my new tranny put in and start driving it again
Parts needing installed: turbo kit from BB (if i ever get it), 9.0:1 CR Diamond pistons, 4340 forged H beam rods, C/J-Spec spoiler, Nissan red tops in KL rails http://www.cardomain.com/id/blazejeremy
Oh deff, for one thing it handles like a dream. Also even with the ZE turbo i can do asecond gear roll(wot) and NOT spin out cause the car is so light it just scoots away. My friend has a civic motor swapped turbo..i beat him by only a lil bit(he runs high boost) but he cant launch in second gear cause he will spin all through it, the little gutted mx3 has no weight that wants to stay at the same speed, so it just goes. we have the same tires also.
