94 mx-3 1.6 DOHC
94 mx-3 1.6 DOHC
what engine will fit my 94 mx-3 1.6 DOCH with no mod or some little mods?
I hear that the 1.7L v6 turbo (K7T) from a 98 626 is almost a direct swap. You just have to swap the bigger ac compressor since it will be used to cool the coolant. Unfortunately those were made and released only in Japan in feb-mar 98. It makes 256 Hp but only 192 ft-lbs torque. Try contacting the japanese importers in your area.
If that doesnt work out try doing a search and read the faqs and worklogs over at the mx-3.com website.
94 Mx-3 Precidia
- cjthor
huh?ariesdude wrote:You just have to swap the bigger ac compressor since it will be used to cool the coolant. .
Jarid Perry
71 Chevy C20 (tow rig!!)
2008 MINI Cooper Clubman S
cjthor wrote:huh?ariesdude wrote:You just have to swap the bigger ac compressor since it will be used to cool the coolant. .
94 Mx-3 Precidia
- 94blaze1.6
There is a number of engines that can be installed while using your existing mounts they are:
BP from ford escort or 90-94 protege
BPT Jdm 323 (turbo)
B6T 1.6 of a capri or 323 gtx US (turbo)
Your transmission will bolt up to any of these without modification
BPT Jdm 323 (turbo)
95 RS so far just a paintjob, rims suspension next then turbo...
I have turbo dreams and detanation nightmares
- 94blaze1.6
- 94blaze1.6
