Man....how can something so little be so much trouble?
Hola,<P>About three months ago the driver side control for the passenger broke. The clip just came off. And what has just happened an hour ago? The driver side control for the DRIVER side window came off. This is bad because..<P>1) I live in florida (It was 92F today)<BR>2) I prefer not to use the air conditioner (Guess Im going to now
<P>So..where would I go about buying new clips and are they easy to install into the control?<P>And no, its not the motor...the clips just broke off.<P>Thanks for any reply
Elena, don't misunderstand. A pro isn't someone who sacrifices themselves for their job. That is just a fool.
David Coleman
Re: Man....how can something so little be so much trouble?
Heck, I'd just JB weld it....much easier/cheaper<P>Whereabouts in FL are you? <P>------------------<BR>David Coleman- <B><I>Moderator</B></I><BR><A HREF="http://www.PinkMX-3.com" TARGET=_blank>1993 Mazda MX-3 GS Special Edition</A><BR><B><I>Why get clear tail lights when only Geo Metros are gonna see them?</I></B>
David Coleman
Im located in the Pensecola/Destin area. Could you please explain JB weld? Thanks
David Coleman
JB weld is an epoxy. I'd just glue the thing up there if you dont want to spring for the brackets. It'll stay...<P>I been through Destin a time or two...
<P>------------------<BR>David Coleman- <B><I>Moderator</B></I><BR><A HREF="http://www.PinkMX-3.com" TARGET=_blank>1993 Mazda MX-3 GS Special Edition</A><BR><B><I>Why get clear tail lights when only Geo Metros are gonna see them?</I></B>David Coleman
ddmalcore
you can get jb weld at your local auto parts shop- advanced auto parts has it. otherwise maybe walmart.
