Coilover and Strut question
So i'm going to be picking up a set of ground control coilovers but when i looked at there website it asked which strut your going to use does anyone know if we can get tokico illuminas or kyb agx's for the mx-3? Or does anyone know of another adjustable strut/shock that we can get that will work with the ground control coilovers?
I'd recommend the ZX2 S/R Tokico struts with 250#/200# spring rates.
The reason they ask is because the body is a different diameter between stock and Tokico's, so there is a different sleeve used.
THINK FAST, GO RACING!!
2004 Mazda6 Wagon
2004 Mazda3 Sedan
1990 BG8P Protege LX - KLZE - Race Preped - #98 SM - SCCA Solo2
2004 Mazda6 Wagon
2004 Mazda3 Sedan
- PATDIESEL
They also cut the coil perch if you tell them you are using ZX/2 struts for some reason. I don't know why as it doesn't seem to need ot be cut, but...
I've ridden in cars with most of those and I like the ZX/2 second under my MS. The MS are not sold anymore that I know of. CorkSport was the only place to get them before and they are not listed anymore b/c they said MS was out of them and not making any more.
