Buying a Mazda MX3 V6 1995.....
topherx
Post by topherx »
Hey guys, new to this website...
my buddie is selling is Mazda mx3 95 V6...he wants to sell it to me for 4,000 CDN..its in good condition, he has new brakes in and new springs and stuff..from when he got it..new battery. But his E brake doesnt work, he said that the string into that connects in there is broken, how much would those things cost? to get fixed.
Juans_93_MX3
Post by Juans_93_MX3 »
If its a automatic dont buy it
Automatics break easily
2008 Mazda 3
1993 MX3 GS
topherx
Post by topherx »
Juans_93_MX3 wrote:If its a automatic dont buy it
its standard
Tunes67
Post by Tunes67 »
e-brake can be fixed pretty easily.. $20 max if you get the cable from a junkyard and install it yourself. $100 if you take your car to a brake shop like Midas or Meineke.
One thing to keep in mind.. while that is a fair price for the car.. being that its a 95.. it could be OBDII. Which means a LOT of the stuff you find here on MX-3.com could be different for your car. Just something to keep in mind. Cheers and best of luck.
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ;)
hgallegos915
Post by hgallegos915 »
another new member.. yay ! :) congrats if you get it. check for rust :)
-hec
mx3autozam
Post by mx3autozam »
Its a 95 so its OBD2...if you decide to swap a Ze you can but acnnot sue the ze ecu on your car unless you swap the entire harness.
John
93 Mazda MX3 KLZE Turbo
mxmaz
Post by mxmaz »
My 95 was obd1. Does anybody even have a 95 v6 that is obd2 on this site?
MRO
Post by MRO »
What does that mean? OBDI and OBDII, I dont get it???
alleycat29
buy
Post by alleycat29 »
newbies ohh so cute... welcome to the wonderful world of MX3
MRO
Post by MRO »
ok so what does it mean??
Famine
Post by Famine »
OBD ("On Board Diagnostics") is a term applied to certain electronic aspects of a car. You know when they plug your engine into a computer? That's OBD.
OBDI (the I in this case being the Roman Numeral, rather than an initial) was the first evolution and differs between manufacturers. OBDII is industry standard - and unfortunately for those who want to drop the 2.5 V6 from the top-spec JDM Mazda MX-6 (referred to around these parts as a "ZE" or "KL-ZE" after the engine code), OBDII makes it just that little bit more difficult as there's no direct way to connect the correct ECU for the KL-ZE to the wiring harness for the OBDII MX-3. The change came about sometime in 1995-6.
However... don't automatically assume that because your car is a 1995/96 model it is OBDII. I have just encountered an OBDI 1997 car (though it was manufactured in July 1996 it was registered in August 1996 which makes it a 1997 car in the UK) which I'm contemplating buying. I should note that this is in the UK and it has been mentioned before that North American and European MX-3s differ on this front - these guys are certainly the experts with the Canadian market and so what mx3autozam says is most probably true.
The only ones that I though were all (or almost all) OBDII were the 96's. From what I've seen 95 where mostly OBDII, and only some of the 94's. I have yet to see or hear about a 92-93 in OBDII
