Top speed test day!!!!!!!!!!!
- freyguy_412
hgallegos915
120 with rev at 6.something i think 6.5 . I dont get the wawawa until i git 7.5 or 7.7 . woah 145 is crazy do you gouys have the stock tranny? i still got the k8 tranny . I must say i got there realy quick...v6 and 4 cyl rocers havent been able to keep up yet. I removed that speed limiter... before it woulodnt go past 110 and would take forever to get there..but after taking that wire out it doesnt stop. I dont have enough road to see the full top speed.
-hec
Re: topspeed
your funny, that like 95 mph lolmx3mike1 wrote:mine does 150 km/h
it's on the probe are now, but it's moving to the mx3 soon.
m62 suercharger, megasqurit, headers,custom exh. 9lb. flywheel, stage3 clutch, & so much more.
http://www.cardomain.com/ride/1301296/1
Hi there, i dont know if the UK gearbox is different? But my lil 1.8 seems to top out faster than a few mentioned here. Im putting in a KLZE engine soon, but keeping my K8 gearbox. When i first got my MX3 my friend and i had a little spin, he as a MGF & we were trying to establish whos is faster, we were both definatley just below 150 MPH, 145+. If anyone doubts this i will get speedo photos etc. This was on the limiter 7.5k Does the KL31 ECU limit earlier. Now i will admit that my MX runs out of puff at around 120mph on the flat but with help from a rather large hill 150 ish was seen! Standard wheels mind! Now im on 17"s
- Limegreen mx-3
I hit 140 on my 92 white BP could have gone more still had more power to go but u never know whats over the hill u know cops fastest ive gotten it.
mitsudriver
i wrapped my speedo completeely around.
My engine sounded like it was going to explode. However it was
fine, my engine runs stronger then ever.
hgallegos915
this bites i can do 110 but the wheel hops all scary
had it checlked all over and nothing came up.. bohoo i think its a bad bearing job..
-hec
papadeez15
