Bad A$$ SOHC turbo
Minimonster
Just for the record. The 451 was in an rs BODY But that was on a BP engine. It was a customer's car so not my call. If lime green would switch back to his SOHC, That would be great. Then we could play.
Proud builder of
455 hp Miata 10.98@125mph
MX-3 RS 25 psi 451 hp
MX-6 F2T 12.8 @ 112 mph
(Current Project) A 700 hp MX-3 now at 475 hp
- Limegreen mx-3
Minimonster are u temping me to go back to sohc. HUMM
Minimonster
Hell YeahLimegreen mx-3 wrote:Minimonster are u temping me to go back to sohc. HUMM
Besides no one answered my Questions yes. I still want to know whats the best and badest SOHC that is or was.
Proud builder of
osargeant
Hey Minimonster,
I dont think there are any big power turbo SOHC MX3s around, since the bulk of the 4cycl MX3s that are pushing out big HP numbers are BPT or BP powered, followed by B6T and turbo 1.6 DOHC ones.
Most persons just dont see the 1.6 SOHC (88hp stock) as a viable platform to turbocharge or to modify period.
JSpec Turbo MX3 (1.6 DOHC)
http://www.cardomain.com/memberpage/310985
Port and Polished Head, Ported Intake Manifold, Valve Job, GTX Manifold, Hybrid Turbo, Cone Filter, 2.5" Exhaust, 2.5" Downpipe, ACT Street Clutch, Lightened Flywheel, MSD 6A Ignition, Boost Retard and SS Coil, Magnecor Plug Wires, Denso Iridium Plugs, UR Lightened Pulley, Spearco FMIC, Turbo XS BOV & MBC, BEGI RRFPR, Supra Injectors, Walbro 255 Fuel Pump, Autometer Gauges, Pivot Shift Light
- hotsiit
hey minimonster...I have a stock 1.6l SOHC mx3 with a T3 super 60 series turbocharger pushing 9 psi. Not really bad-a-- i suppose, but it has never really been tuned or dyno'd yet, but it is alot more fun than stock.
My sohc mx has also been turbo'd this way for over 3 years now, with no real problems.
1993 Mazda MX-3 RS-Turbo
1993 Mazda RX-7 touring
1983 Mazda RX-7 GSL
1987 Jeep Comanche
1983 Mazda RX-7 GSL
1987 Jeep Comanche
- Limegreen mx-3
I've decided to postpone my BP turbo project and miss around with my other MX-3 1.6 sohc. Find out what (everyone call the suposed piece of S!HT engine) can do and whats its limits are on stock internal form. Put an end to it can't do that, just can't be done, just swap it for the BPT. Minimonster and I have yet to hear of any MX-3 sohc owner (other than hotsiit) thats has pushed it in the sohc.
with this going to be done at racingmazda the intensions are to find out what the B6-ME can really do with proper EM, put and end that a sohc can't get 300whp. if we can make we make if it can't be done well then u guys where right. end the rumors that the sohc a POS or not.
within the next six months me and turbo ric will find out what a bada$$ turbo 1.6 sohc can really do. wish me luck or piss on my luck which ever i want to find out the turth.
- BuGS
I think it can be done, but their is a difference in Horsepower vs $$ ratio. After so much HP on an engine it takes so much more $$ to make more hp. So I think we have all thought that it wouldn't be efficient. But I give you a "good Luck" If you have success then I might talk one of my cousins friends w/ a SOHC to turbo it.Limegreen mx-3 wrote:put and end that a sohc can't get 300whp.
- XxantwawnxX
Id love to see ya get 300+ hp on stock internals and see how long it lasts. It would be awsome.
- MechaManZero
lol unfortunately thats when s--- starts to hit the fan and break my friend.XxantwawnxX wrote:Id love to see ya get 300+ hp on stock internals and see how long it lasts. It would be awsome.
Çlark
95 Mazda MX3 4 Banger
Currently: H&R Lowering springs, BPT from a GTR, 18.5x6x3.5 same side inlet and outlet intercooler, Centerforce Dual Friction clutch
For BPT Frorums - http://www.aokforums.com/mazdaengines/
- XxantwawnxX
I know, and i love to see it : PMechaManZero wrote:lol unfortunately thats when shat starts to hit the fan and break my friend.XxantwawnxX wrote:Id love to see ya get 300+ hp on stock internals and see how long it lasts. It would be awsome.
Bochek
ooo im pumped, hopefully this will give me some good insite into what i can expect outta my sohc.
Bochek
Bochek
Adam Bochek's 93 1.6L SOHC http://www.bochek.ca/car.gif
JWMotorsports
The most powerful SOHC I've ever seen was YEARS ago...Burnt Orange Metallic paint, ram air scoop in hood above stock airbox location and made 400+HP w/ a T3/T4 hybrid.
- atlantamx3
soulsynchromachine
Bochek
your thinking of megatweak, you load in log files and it tweaks your afr and ignition maps.XxantwawnxX wrote:No im not talking about megatune, its an option in megatune, at least it is in mine. I just forget what it was and i dont have my laptop atm.
Bochek
