I Got oily Spark PLUGS!!!!! im really scared
- PWRD_BY_HKS
I Pulled out my spark plugs because as you might have already read im going crazy mann i already blew two engines and on the part that actually screws in i have alittle bit of oil but . HOW BAD IS IT????
jdmx-3 KID OF THE
VICTORIA RACING
ZE PERFORMANCE IN 915 TX
Kl01-ZE,Kl31 ecu, millenia manifold, ngk plugs, ngk wires, probe tranny/ and clutch (stock), VortecH FMU 12:1, Aeromotive AFPR, Tial .38mm Wastegate w/ 4lbs spring, Walboro 255 pump, AiResearch T4, 3" down pipe, GODSPEED manifold, Spearco Boost Gauges, BF Goodrich G-force drag radials.
14.8 1/4 mile all motor untimed on boost.
VICTORIA RACING
its on the bottom BUT engine DOES NOT smoke white... engine runs good, engine doesnt burn oil.. Im like WTF dam if it is the engine its settled that i wont get a ze. I already drive my kf like CRAP every single day and its doing good. Ive heard alot of ze horror stories on how a non rebuilt ze always dies at any sign of really hard driving :/ Imma go see it today for my self to see whats up. I dont thnk its the piston rings, if it is oil in chamber im thiunking more of valve seals.
-hec
- relisys_3200
- solo_ryder
- PWRD_BY_HKS
its dry from the top the only part wet is the thread
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
- XxantwawnxX
Valvecover gaskets, not to hard to fix (rear is a little harder)
- PWRD_BY_HKS
okay ill change the valve cover but could someone please explain how in the world oil on the threaded part has anything to do with the valve cover........wouldnt the oil be on the top where it plugs into the valve cover...... how would it get to the threaded portion where the spark is gapped ??? - sorry man no offense to anyone i just need to be told things in d-tail to understand
jdmx-3 KID OF THE
VICTORIA RACING
VICTORIA RACING
- babyblueMX3
if the VC was leaking, he would have had oil on TOP of his plugs normally and a little on the side when he takes them out
RIP 400whp ZE-T MX-3
- solo_ryder
a days work not even juts didi mine yesterday, and y athe rear is a b----. had the same problem wasn't getting a spark anywhere so i check all the plugs and found one with oil on it so i reseealed the cover, also i changed the distributor to see if my car would start, but my friend misplaced my key (for the second time) and i couldn't start it to test it.
