"Intermitting" misfire and "power train"
MOSES
Post by MOSES »
I was bootin down ther highway today, noticed my CEL came on so i pulled over just for a checksy.
she was idling really rough and low, so i drive it to the shop turn it off, when i turn it back on 5 min later it was idleing fine, but still had the CEL in.
ITs been intermitting all evening, but doesnt shut off.
people get misfring with bad fuel pumps, bad spark plugs, bad wires, but this is intermitting, so, i dont believe its any of these.
I've been so unsatisfied with my car since I joined mx3.com.
Seeing all the body kits, rims and engine swaps makes me want to spend all my student loans on my car.
kiwi_MX3
Location: Backpacking in Canada in vancouver 13march onwards
Post by kiwi_MX3 »
My hack car has a intermittant problem, but does'nt list any codes
when pulled,
however id pull the codes from the ecu and see what
comes out,
MOSES
Post by MOSES »
thats what i meant by "power train"
thats the code that the scanner pulled,
thats all it said.
slimmyslim1420
Post by slimmyslim1420 »
MOSES wrote:thats what i meant by "power train"
thats all it said.
Is your car OBD2? If it is OBD1 what did you do to pull codes?
1992 GS ZE swap 94 dash swap drilled and slotted rotors full ceramic pads CS SS clutch and brake lines KL-36 ecu zx-2 tokico struts eibach springs short shifter Tenzo exhaust Hi flow cat 2.5 in piping
MOSES
Post by MOSES »
i drove it to the shop, they have a scanner or "code reader"
The scanner came up with "power train".
what the hell is that?>
hgallegos915
Post by hgallegos915 »
missfiring interminiene = hei you forgot to mention that, also timing, disty of clogged fuel filter. This issue i ahd for over 3 months. I was ready to trow my car away and it ended upo being the hei.. so um obdI or OBDII ?
-hec
MOSES
Post by MOSES »
forgot to mention Hei? I dont even have that setup,. im runnin stock here.
I have the year of car where you cannot pull the codes with the cel light using the ten and grnd procedure. I dont know if thats obd1 or 2.
XxantwawnxX
Post by XxantwawnxX »
OBD2
