replacing thermostat
- Drewation
im sure its been asked a million times but can someone tell me or show me a post with all the steps to replacing it, also where it is located?
thanks
thanks
- 1992blazeredgs
its a pretty straight forward process. There is a bunch of intack hoses to remove to allow better access. I f you have a digital camera just take a couple of pictures so you know how to put it back together. When you put the new therm in just make sure you put the little burp hole at the 12:00 position. The online manual is a great tool with good step by steps.
Hope this helps
Twoie
Hope this helps
Twoie
- Drewation
so, i got the new thormostat in reaplced everything to how it was. first i forgot to connect the electrical connection to the intake which was making it run really rough and finnaly died. so i pluged that in, then it seemed the battery had gone dead (i had my stereo on while i was working). so i left it to charge came back 2 hours later, nothing happend at first the on came on but suddenly everything started to go screwy lights comming on and off gauges going up and down. so i found the problem the ground bracket that connects the the metal tubing that houses the thermostat i forgot to connect
. now i havent put it on yet but ive left my car at school for now, but my question is, do you think i would have fried any electrical stuff? and if i forget to ground would it have blown a fuse first?
