belt on k8 what type of lube to use
i park my car in a garage for 2 days i start it up and a loud very very loud scrapping or a sharp cracking noise occurs. I open hood and bingo! its the belt, i checked it. It looks fine from my vantage point. any lubes to spary on the belt so its more "smooth" ? if it dont reslove it i will prolly remove the belt its time for a replacement anyways just wanted to know if there is even a type of lube for belts?
Team Woozy
Wu-z Performance
(twenty one twenty)
Wu-z Performance
(twenty one twenty)
- mx3autozam
Don't lube belts. iuf there making that noise usually menas time for a new belt or maybe a tensioner. Lube or belt dressing will work to make the noise go away but the belt will still slip and probobly more.
Just get a new belt and idler pulley bearings and it will be fine.
John
John
93 Mazda MX3 KLZE Turbo
- Custommx3
- Site Administrator
Old school trick.
If you have oil on your belts or something thats causing the squeek...
I was told to use some dish washing soap on it without water. It will squeek for a short while but will clean the belt off.
You may need to tighten the belt. If its the laternator belt I had a smiliar issue, turned out I had a bad bearing in the alternator causing some "drag" that was making it squeek.
- jschrauwen
