Front/Rear rotors
kaioken
Front/Rear rotors
Post by kaioken »
Does any body have or know, where I can get the technical drawings for the 256.54 mm front rotors and the 251.46 mm rear rotors?
jschrauwen
Post by jschrauwen »
Would the Online shop Manual work for you, page TD-024. http://www.mx-3.com/index.cfm
kaioken
Post by kaioken »
Wow this Online shop Manual is nice. I never really messed with that. I can use some of that information on TD-024. If I cant fine any of the information I'll just have the machine shop take the measurements.
But what im looking for more of something like this with all the specifications for the mx-3.
You mabe wondering, what I want this for. I am building a Rally Car for G5. I plan on useing Wilwood Caliper and there rotor but I have to have my own Hats made. I have a sponsor that is doing all my machine work.
PATDIESEL
Post by PATDIESEL »
You should be able to use a micrometer to get the measurements easy enough. You only need the offset, hub ring size and inner diameter of the hat right.
kaioken
Post by kaioken »
Yeah pretty much. I was just hopeing to see if mazda already had that information for me. but Oh well I take the measurements my self if needs be.
