KLZE owners
Hmm, well that does kinda make me feel better about the origin of my engine, because I definitely have the KL01 cams. I'm not sure what could be "bad" with the engine, to make it not put out the power it should, but run fine otherwise. Wouldn't we have other symptoms? I used to think it was running in a limp mode or something, but I've also tried several ECUs, with no real difference (other than idle issues and VRIS changes). Don't get me wrong - the car is quick, a lot quicker than the K8, but it's just not what I expected.
Hank
'92 MX-3 ZE *SOLD*
'05 RX-8 Touring
--All those who wander are not lost-- JRR Tolkien
'92 MX-3 ZE *SOLD*
'05 RX-8 Touring
- MX3 GSR for dummies
Nd4SpdSe wrote:I checked with Barry, he sais KL01 cam'd KF's dont exist. Part of me doesn't want it to be a KF, but part of me does, cause it would be a nice explanation, and that means I would be the first Mx-3 with a KF, but I doubt it, I probably just got a bad KLZE
You probably need to fix that puppy up. tuning is the name of the game. Simple things from cleaning the interior of your TB to changing pully's can make your ZE run fast. Remember that engines never work at 100% efficiancy and deminishing the efficiancy is easy too. I would pull off your TB and clean that. It's a little time consuming but can make a word of difference!
EDIT: Has anyone tried that chip on ebay? For 50 bones I don't think it would hurt....
http://cgi.ebay.com/ebaymotors/FORD-PRO ... 3058QQrdZ1
If at first you don't succeed....it never happened
94 mx3 GS w/ KLZE, KL31 ECU, clutchmaster stage 3, cross drilled rotors, Custom ram air intake, Custom exhaust, Toyo tires, 250LPH fuel pump, Modified Distributor, Upgraded Wiring etc, external HEI, Full Body Drift kit and freshly painted Grey. Interior neon accents and much more in progress
