I have a 92 mx3, and i need new belts.. I want to do it myself and I was just wondering, if the belts were on a tensioner? if not how do I replace them? let me know thanks
Antoni
replacing A/C and alternator belt
- SnoSurferr
You have to take the Alt. Belt off Before you get the A/C, For the Alt. Belt, Loosen the bolt holding the altentator tight to the mounting bracket. Slide the alt. Towards the engine, And take the belt off. The lossen your Power stering pump from its bracket, This on is trickey because the pulley must be in the right place to loosen the bolt. After you accomplish that, Then Do it again but in reverse with new belts, = ).
Hope this helps,
Mark
Hope this helps,
Mark
