well the AWD MX is going under alot of changes in 06'. the first thing is a 1.9L BP Turbo motor producing somewhere around 300 ponies with the VF10, It should be close to 180 N/A from what im told @ 8.6:1 comp. its a monster (and visually you can see it when you open the hood, its just too bad you cant see the forged inturnals). its going in in JAN. then i got the GC's with a custom spring rates, a J-spec solid rear sway at 20mm, probably a rollbar, and some paint this summer. with a custom front lip and rear lip that if all goes well i will produce several copies. and a custom deck spoiler. alot of changes
plus Bugs and I are helping a buddy in MX-west build his MX. The goal is 300 WHP, with the super 60, and a mildly built BPT. and full suspension, and alot of custom body work, pretty much a cross between the MX and the RX8 front ends. should look nice. then finnishing it off with a nice paint job. I have a bussy 06' ahead of me.
