[FS] 94 gt parts out performance & stock
i am selling everything so here your chance to get some stuff. i posted it on probetalk.com
http://forums.probetalk.com/showthread.php?t=1701181335
it's on the probe are now, but it's moving to the mx3 soon.
m62 suercharger, megasqurit, headers,custom exh. 9lb. flywheel, stage3 clutch, & so much more.
http://www.cardomain.com/ride/1301296/1
ok i gave people on probetalk a chance at these parts now i will give you guys a chanc at them. first the performance stuff. my zip code is 09182 go to the usps & put in the wieght to know what shipping will be. you tell me what priority, but it will be going out by usps
1. two complete set for heads (kl) new valve job & seal’s ported & polished, heads are shaved (no head bolts) with lifters. No cams (I broke one) wieght 65lb total
asking $300.00
2. 67mm TB with tps & iac 7 lb.
asking 120.00
3. obx header 32lb.
asking $200.00
4. pmo traction bars 10 lb
asking $100.00
5. Fidanza flywheel W/ Clutchmaster stage 3, pressure plate, disk, pilot bearing, stainless clutch line. It has only 6 passes down the ¼ & less than 2000 miles. you can even still read the lettering on the disk. i think it's 35 lb. with everything, i will try to wiegh it today
asking $550.00
6. set of ze cams, (has some nicks, but no problem all are below surface) 18 lb. asking $200.00
7. EDIS 6 setup. I did most of the work for you all that should be left is make the mount for the sensor. Even got the custom wire for you asking $175.00 15lb
8. phenos spacers
asking $50.00 5 lb.
9. Innovate lc-1 WB o2 sensor & controller, with the xd-1 display
asking $300.00 8lb.
most of the parts have 2000 miles or less are in great shape
asking $300.00
asking 120.00
3. obx header 32lb.
asking $200.00
asking $100.00
asking $550.00
8. phenos spacers
asking $50.00 5 lb.
asking $300.00 8lb.
i could also use a couple parts for my mx3.  i am doing a auto to manual convertion.
i still need both pedal assmble's the hydralic's from the pedal to the slave cylinder. the complet shifter assmble, & if my clutch sells i need a stock clutch set perferable a mx3 flywheel. would be willing to trade some stuff.
- hppwdn
I saw someone on PT was interested in the traction bars.  Did he fall through?  If so I'll take them.  I checked the USPS site and shipping to my zip (33021) should be about $15.
Let me know if they are still avail and I'll paypal right away. These are the ones with the long black piece and two rods that go out to your control arms correct?
92 MX3 Turbo  ($100 junkyard KLG4) 11.904 @ 124.3mph, 14psi, DOT approved Hoosier drags, pump gas.
they are still for sale. if you go to my car domain (bottom of my sig) 2nd page,first picture.
- hppwdn
I was hoping for the original design. That's also what I estimated shipping on. I had them on my old probe and wanted to get some to chop up and make fit my MX3. I like the old design the best.deathman wrote:they are still for sale. if you go to my car domain (bottom of my sig) 2nd page,first picture.
I'd do $80 shipped on these. I just don't have the same confidence in the new design as I did on the old.
i also need two head gaskits for my kl v-6 motor. if some one has some i would be willing to trade something of same value.
the new type traction bar work just fine, i had no wheele hop after i put them on.
will if your going to chop them then it wouldn't be that hard to make them into the older type. you have all the major parts. all you need is two small pieces of steel that go under the tow hooks, & a piece of square tubing. thats if you have a welder & lnow how to use it.
i can't go 80 shipped, maybe 90 & you pay shipping.
by the way if you want i can make them like the older type for you, but you would have to pay for them first. the only think that will not look as nice would be the traction bar itself. i would have to cut them & add some materal.
- hppwdn
I'll stick with 80 shipped the way they are.  I've got all the measurements from the old style and have been meaning to order the stuff to make it.  I have the welder and all the equip I need, I've just been too busy.  I figure if it's a decent deal I'd give these a shot.
i already said i can go 80 shipped, i payed way more than that for them. 90 & you pay shipping.
- hppwdn
Oh well.  My offer stands if you change your mind.
i will look into it, but i will not do anything to them untell you make full payment. wouldn't want to start cutting these up to fit then find out you don't want them anymore right. i need to look & see how much work this is going to be before we agree on a price.BuGS wrote:If you make the Traction bars so they will fit my 92 4cyl MX-3 I will give ya $120 shipped. But they have to fit perfect, or close (BTW I don't have a welder)
i will let you know something by tuesday at the latest ok
johnnie
