blow valve with MAF??
I was talking to a guy yesturday and he said I cant run a blow off valve because my engine has a mass air flow sensor...is that true?? I have seen some DOHC B6 motor boosted with blow off valves..so whats the deal??
- Josh
thats a crock of crap. you just cant run your BOV open to the atmosphere. you have to run it back in line before the MAF.
But that all depends on where you put your MAF. now if you put your MAF after your IC just before your TB, then you can run your BOV open to atmosphere. the BOV just has to be before the MAF. that way the MAF wont read the loss in air. other wise it will think you have a vacume leak, and your idle will fluctuate.
NO. You want the BOV as close to 6in to the TB.
It should go TB, BOV, VAF/MAF the IC.
The BOV is to protect the cold side of the turbo. When the TB closes the air bounces back, and BOV is there to release the pressure to protect the cold side.
You dont want air flowing the wrong way through the MAF/VAF. That will mess up you a/f as said.
GS + BP + T3 + 9lb flywheel - some dead weight =
so it wouldnt work right if i put the MAF between the turbo and the filter....and the blow off valve between the throttle body and the intercooler!!
Because i was looking at the mx-3 from 2 fast 2 furious the same set up as what i am doing and that is how his is set up!!
Here is that page i am looking at:
http://www.cardomain.com/ride/282371/2
If you want to vent your Bov and not have a problem with idle it needs to go.
Intercooler-->BOV-->Maf/Vaf-->Throttle body.
But heres another arguement for you.
Why do you want to Bov as close to the throttle body? Wouldnt it make more sense to place it before the intercooler? So the intercooler isnt doing as much work to cool the air.
it dosent make much sense to me to vent cool air, id rather vent hot air.
92' Rs-t b6t/De - RIP
93' Rs-t BPT - Sold
03' WRB wrx Wagon - Current
93' Rs-t BPT - Sold
- XxantwawnxX
To work right it has to go BOV----> MAF/VAF------>TB becauseif you put the BOF after the MAF the MAF well measure the amount of air and such liek its suppose to...but then ur BOV well let some of that measured air out...giveing ur comp false readings.
- Josh
To work with the MAF for an atmospheric BOV you have to go
Filter-> Turbo-> IC-> BOV-> MAF-> TB
this way the MAF wont read the loss in air.
to run it properly with the MAF as if it wre stock it needs to be
Filter-> MAF-> Turbo-> IC-> BOV-> TB
and you cant run it this way with the BOV to atmosphere, as the maf reads the drop in air. so you have to re rout the exit off of the BOV into the piping somewhere after the MAF and Before the Turbo.
and it really doesent matter where the BOV is located, as your piping has constant presure. alot of subarus and Volvos come with the BOV mounted to the IC. its all personal preferance
