Question!
Car Stereo/Alarm Discussions
AshesofPepper
Question!
Post by AshesofPepper »
Alright i'm sure this has been asked before but i did search for it and came up empty-handed.
Does anyone actually have their deck MOUNTED, as in secured, in the stock location and if so, how? At the moment my deck is sitting free in the stock mounting location, and skipping like hell :oops:
I'm sure there's a vehicle specfic kit i can get to solve this but i have no clue where to start looking.
Any suggestions?
92' 1.8L GS with more problems than i would like to admit.
Typhoonk
Post by Typhoonk »
if you deck was brand new it came with a cage that slides over the deck and clips in.
1. Take cage off
2. Slide cage in car hole.
3. Push taps in cage out to hold cage in.
4. Plug in deck and slide deck in till it clicks. enjoy.
if you bought it used u might not have a cage. Where do you live? and what kinda deck do you have? maybe someone has a spare cage you can have :) :D :lol:
PM for info
Legato626
Post by Legato626 »
Ya those dumb tabs... Easy to put in pain in the a-- to take out... Ya just push the top 2 in the sides and the bottom pins down then slid the deck in and now your good.
1994 Mazda MX-3 KL-ZE
AshesofPepper
Well i got the dack new, so the slide plate(cage) is still on it and i'll go install it properly now.
thanks!
Legato626
Post by Legato626 »
make sure you take the cage out first On the face plate edge ont he two sides they are cliped in some how. That will get the cage off.
MX-SLICK
Post by MX-SLICK »
there is just simply not enough speace to accomodate all the wires behind my deck, this is why no matter how hard i press my deck will not lock with the cage.
94' MX3 GS atx
93 geo storm GSi
99' Ford ZX2 mtx
2001 honda CBR 600
2000 kawasaki kx 500 MX
Typhoonk
Post by Typhoonk »
measure it, but it will fit. U have to tuck the wires down the sides and stuff
unless u are using RCA's for amps and the RCA's are like 2inch long plugs on em :shock: it will fit
PM for info
Legato626
Post by Legato626 »
I have a 5 volt eclipse I HAVE MORE WIRES THEN YOU!! The eclipse decks (the 5 volts and 8 volts) have a crap load of wires. The amp ports and the radeo and crap i dont even need i have all on wires.... You juve have to wiggle get under behind the dash and pull a little and it will slide in.
MX-SLICK
Post by MX-SLICK »
why would 5 volt make a difference? It is simply a measure of the RCA signal level, not the quality of the deck. My panasonic has 5 sets of RCA's...Front, Rear, Subwoofer, Auxillary1, and Auxillary 2...4 of which are being used and they are fat RCA's. I also have a big wire for XM radio adapter, and the rest of the wires. There is just no room. I have to figure something out, lol..
94' MX3 GS atx
93 geo storm GSi
99' Ford ZX2 mtx
2001 honda CBR 600
Typhoonk
Post by Typhoonk »
MX-Slick all that is behind your deck is the plastic heater tubes, just get a heat gun and melt it a bit and push it in with a peice of wood. Should be able to get just enough clearence for the deck
PM for info
Return to “Car Stereo/Alarm”
