MX3 fat or big boned????
Uriel_Soulflare
Post by Uriel_Soulflare »
Hello. sorry for asking this but how much does the GS REALLY weight? I ask because i bought this car specifically for its light weight since i heard in a forum that it weights around 2500 - 2600 Pounds. Now when i ran a program called "CarTest" it says the MX3 GS weights 2700, THEN when i check my car (On the side of the driver's door) says above 3000 pounds :shock: (!)
Is this correct?? I cant believe the MX3 is this heavy, ive seen 4 door cars that weight less than this. Sorry if i sound a little paranoid but i chose light weight-ness over power when looking for a car and tuning this car is REALLY expensive and hard to do (But im sure you all know that :P ) i could live with 2700 and loose a couple of panels but 3000! My cars a fatass! >_<
Thanks
P.S. Discuss weight in pds instead of Kgs Thanks
Hoodzy
Post by Hoodzy »
the stickers on the cars never tell u the weight of the car they tell u load capacaties and such of the tires and all that jazz
it weighs roughly around 2400 pounds, but then if u have stereo equipment and u in it then add another 200 pounds
1995 Creek Mica Blue GS
XxantwawnxX
Post by XxantwawnxX »
Yeah dont go buy the stickers on the car..thats a totally diff thing. Our cars are around 2500ish depending on some factors.
Uriel_Soulflare
2400? you sure? I know it was really weird because the V6 engine is like 600 Pounds and the back of the car is pretty much just the hatch and most of the weight is in front. So how do you know exactly how much the GS weights? isnt there a manual or something from Mazda that tells you these sort of things? I think it has to be a little above 2400 cus thats what the Miata weights i think but i pray your right :P
True, but the Miata being a convertable may have structural reinforcement adding to it's weight, as well as a added RWD components that our FWD car's lack
Uriel_Soulflare
lol i was always afraid of Miatas (Have you seen people getting out of those cars???) Thanks for your replies, Now if anyone has an exact number (Stock GS) i would appretiate it :)
Gro Harlem
Post by Gro Harlem »
get ur facts straight!!!
the GS is 2540 lbs for the manual, about 76 lbs heavier for the automatic model
the RS is something like 2460 but i'm not 100%.
DONATE TO MX-3.COM
mxmaz
Post by mxmaz »
gs weight about 2550 lbs and the v6 engine is nowhere near 600 lbs, its more like 400 or a little less with everything attatched
Mnemonic
Post by Mnemonic »
This is the info i have on the weight
92 gs auto 2618 lb
92 gs manual 2567 lb
93 gs auto 2620 lb
93 gs manual 2567 lb
94 gs auto 2646 lb
94 gs manual 2600 lb
01 Lexus Is300 (LS2 Project)
93 Mx3 SE 2.5 KLZE (sold it)
Uriel_Soulflare
2540? Thanks! thats a nice number :D Sorry i dont have the manual my car is used i bought it recently cost me 2K with 119Kmiles on it, im thinking of getting the ZE engine when i reach 200Kmiles and fixing the rest of the car in the mean time. Wow getting a cluch in this thing costs me over 300 bucks (Including the clutch) turns out a common oil leak got into my transmission and into the clutch killing it plus another part in there i cant recall the name, something that needs cutting because it got missaligned and bend. Well Atleast now i know is worth it :wink:
The moral of the story watch out for oil leaks in a compact FF car! >_<
Last edited by Uriel_Soulflare on September 26th, 2005, 3:15 pm, edited 1 time in total.
Uriel_Soulflare
2540 says on the Car's manual? Mneumonic where did you get those numbers? altough is only a 20lbs difference
lakersfan1
Post by lakersfan1 »
Uriel_Soulflare wrote:2540 says on the Car's manual? Mneumonic where did you get those numbers? altough is only a 20lbs difference
The actual curb weight was posted in all the major car magazines when it was tested in 92/93. It was also in the MX3 sales flyer.
And the K series engines weigh nowhere near 600 lbs. They're closer to 300 lbs for the long block.
neutral
Post by neutral »
Info is linked on the mx-3.com main page. See it directly here. Scroll down 2/3 of the page and the GS curb weights appear. http://mx-3.com/brochure/specifications.cfm Specs are right out of the Mazda Factory Shop Manual.
GS MT/AT: 1171 kg (2582 lbs)/ 1194 kg (2632 lbs)
And right, ignore the sticker on your door jamb. That is your specifiied GVWR - Gross Vehicle Weight Restriction, not actual curb weight, but the max total weight the car should not exceed to maintain manu rated safety/handling. GVWR would include full tank of gas, passengers, luggage, FATHEADED mother-in-law, etc. Oh, and that last one will possibly crash your suspension or blow out yer tires if it weighs too much.
Image -Jim
Uriel_Soulflare
Thanks a lot that sums up everything, i didnt find that link in the front page weird :?
Gro Harlem
maybee a/c or the power package adds 27 lbs? who knows...
i got the info from carpoint.msn.com
DONATE TO MX-3.COM
