My Lights Are Effed Up..
				propagandhi420
alright this is a little problem that has been bothering me for years... when my lights arnt turned on... its like out of nowhere they have a mind of thier own.. they will flicker on and off at random times..somtimes it doesnt do it for a week..somtimes a month... but they just go crazy on thier own..only way to stop it is to turn my lights on all the way.. i think maybe i invested to much money into a POS!!
							<a><img></a>
				propagandhi420
- jschrauwen
Re: My Lights Are Effed Up..
These are the DRL (Daytime Running Lights) that are on (or supposed to be on) but now are flickering when the light switch itself is not turned on. These can be turned off by pulling up on the hand brake which has a small (push/release) switch located under the hand brake lever itself. When your hand brake is all the way down it compresses the switch ensuring that the DRL's are on. By lifting the hand brake lever the switch is "opened" and it turns off the DRL. I'm thinkin' that this little switch has become loose over time and just needs to be tightend down and maybe perhaps the height position adjusted so that the open and close function is occuring exactly when it's supposed to. Normally the switch should be activated when the hand brake is lifted a very small bit from the all the way down position. Once you remove the armrest/hand brake consol it will be become self evident and the adjustment/tightening should be a breeeze. This is just a guess because you should (I think) see the brake warning light come on, on the dash at the same time this flickering occurs since they are related, but you haven't mentioned that part so that's why it's a guess. Grants can back me up on this, I hope. Good luck.propagandhi420 wrote:when my lights arnt turned on... its like out of nowhere they have a mind of thier own.. they will flicker on and off at random times..somtimes it doesnt do it for a week..somtimes a month... but they just go crazy on thier own..only way to stop it is to turn my lights on all the way
*John*
If its something to do with the DRLs I'm lost. I haven't got a diagram for them so I don't know how they are meant to operate unfortunately.
If its just the headlights and nothing to do with the DRLs, theres a diagram here:
http://www.mx3er.com/Info/1993%20Wiring%20Diagrams.pdf
Figure 9 grid position D33 which shows the headlight circuit.
You can see from that diagram that the ONLY thing that can supply a ground to the headlight relay to make it operate is the headlight switch itself.
So I'd be thinking:
- faulty headlight switch (unlikely as its too intermittant and you'd expect it to get worse over time. But you could try and spray the switch mechanism with WD40 - it won't hurt to try)
- faulty relay (unlikely if you can hear it clicking but you could swap it out with another one pretty easily to prove - you can just use another one from the car to do this. Is the TNS relay identical to the headlight relay (its under the dash too)? It would be a good one to transfer the fault to)
- intermittant short to ground in the BLUE / YELLOW wire between the relay and switch. By moving and shaking all the wires in the column may prove this one.
So I'd be thinking:
						- jschrauwen
Sorry about that Grant, didn't know AU Spec didn't have DRL's.  Then again, I should have known that the J-Spec and AU-Spec are basically the same.  "420", never mentuioned where he lives so it was just an assumption on my part that he was NA.  The handbrake switch is very similar to the push release type switch used on the doors for the interior lights.  This hand brake switch does trigger the TNS relay as well as illuminate the "brake" light indicator on the dash when selected.   As per normal ..... ie, AU Spec should give the same dash light indication when the hand brake is selected ...right?
Yes the hand brake operates the "brake" light indicator (which is also the same indicator as the brake fluid level) on ours.
Those DRLs seem overly and unnecessarily complicated from what I have seen....
						- jschrauwen
You can say that again ... a real PITA. It's going to take a bit of work to circumvent them when it's projector time and now I'll have see how everything plays out when I go to install my J-Spec front bumper. I may have to source your wiring schematics for the connections for the J-Spec foggies/turns since on initial inspection it looks like the connectors for the foggies are tied into the connector for the park/turn signals and I don't think the NA spec connections will be the same. Might have to get creative.Grants wrote:Those DRLs seem overly and unnecessarily complicated from what I have seen....
				reaper of souls
unplug your  dtr lights for a while and see if the problem happens again the day time running lights control box is right above your battery close to the fender  it's a little rusted box (well mine was rusted) you should be able to see a plug going into it just unhook it and they'll be disengaued that should solve the problem.  only question for you is do they do this when there on as well if so it's time to rewire your headlight there a short
							 96 X-90 4x4, 16v custom ram air intake lockers front and rear with 5.83 ring and pinion.
 96 X-90 4x4, 16v custom ram air intake lockers front and rear with 5.83 ring and pinion.Ok, I found the diagram for the DRLs. If propagandhi420 can hear the relay clicking, it can't have anything to do with the DRLs. The ONLY thing that controls the headlight relay is the switched ground in the headlight switch (the DRLs use a control unit in the RHS kick panel that doesn't utilise the headlight relay but supplies power in parallel and independently).
The diagram is here, page 14:
http://www.mx3er.com/Info/1995%20Wiring%20Diagrams.pdf
So I'd be going back to my previous post and checking everything in the headlight control circuit (switch, relay or short in what now looks like a RED / BLUE wire (not BLUE / YELLOW as previously suggested from the other diagram)).
				propagandhi420
- jschrauwen
Your about 30 minutes from me and I might be able to swing by in a few days and have a look.propagandhi420
				propagandhi420
- jschrauwen
- jschrauwen
