Comedy Tyre Change
A place for the MX-3 Community in Europe to gather.
garfy1981
Comedy Tyre Change
Post by garfy1981 »
Well just had flat tyre on the front, luckily it was only 2 mins down road from me but anyhow, did take a while !!
Problem number 1; couldnt find the jack anywhere, dont know where thay are usually kept on the mx
So went back home luckily ive got a two ton trolley jack in shed
Problem number 2; as ive lowered car i was about 20mm short of getting the jack under car!! So i had to wait for stranger to walk by so they could push jack under while i lifted front wing !!!!
Anyhow changed tyre for the space saving wheel which looks ummm... pretty. Then had to wait for another stranger to get jack off car again :oops:
In all took about 40mins for one wheel !!,
Any ideas about jacks for lowered cars?? a bottle jack would definately not fit, im on standard 15" rims at the moment so theres only 12.5cm from car to ground :shock:
2.5 Ze straight neck, blitz intake, mazdaspeed engine mounts, fidenza flywheel, CM II Clutch, KL-36 ecu, Magnecor 8mm Leads, Battery Relocation. Hotshot headers, 2.5 mandrel bent stainless exhaust, hi-flow cat, Speed hut dials, custom coilover set up. Custom willwood big brake conversion.
GregoryChristian
Post by GregoryChristian »
I definetly know that jacks for lowered cars exist, I saw one on a tuner show here in the States a few months ago .
Teal_93
Post by Teal_93 »
I use the stock jack stored in the back of the car to lift one side so i can get my floor jack under the front. Same with letting the car back down
Grants
BANNED Member
Post by Grants »
You can buy low profile trolley jacks - they're usually aluminium so are very light too. They're used a lot in racing. Unfortunately though they're still too big to cart around in the car to be used for breakdown purposes.
garfy1981
Post by garfy1981 »
Many thanks for your replys, good to know that such a thing does exist so I shall definately be looking it. I was hoping it would fit in the boot to carry around but never mind :roll: . Cheers guys!! Car still looks rocking on its space saving cycle wheel !!
Return to “European MX-3 Community”
