wierd A/F gauge problem??
Ok when i push the brake pedal down my ari/fuel gauge goes to full rich!! What could be causing this problem??
Domnknpimp
forcedairram
wiring
sounds to me like a wiring problem, if you hook a wire up wrong it could screw with the reading
http://www.cardomain.com/ride/1404826
BROKE DOWN POS
BROKE DOWN POS
I just bought a A/F Gauge and it says to make sure to NOT ground out the ground wire to a ground inside the cabin of the car and to only groudn it useing an engine ground... Maybe the ground you are using has to do with something in the grounding of the brakelights?
That's abotu the blindest stab I could take, but It's worth a look. Sounds like a wireing thing to me.
1992 MX-3 SOHC 1.6
15" 5 spoke star wheels with 195x50 Futura sport tires. Solid filled Poly Urethane motor mounts. Short throw shifter, aluminum and carbon fiber shift knob. Ebay Cold Air Intake, 2" Custom Cat Back exhaust with Glass pack muffler and 3" slant chrome tip. Dual 10" JBL's with Kenwood amp with neon pulsating light, dual 6x9's in carpeted box, Clarion head unit. Custom blue/black interior.
matt_fulghum
It goes really rich, I imagine, because the brake booster runs off vacuum, so does your fuel pressure regulator. The less vacuum the FPR gets, the higher the fuel pressure.
At least, that makes sense to me, and that'd explain it, sort of.
A/F gauges are pretty much useless though, fyi.
my cardomain site: http://www.cardomain.com/memberpage/793483
