CLICKING NOISE
plusinfinit
CLICKING NOISE
Post by plusinfinit »
I have a slight clicking noise that sounds in a very metalic way. It is a 93 sohc stick. I changet waterpump and belts 2 years ago. So i doubt it is the waer pump. I also doubt that my timing belt is loose, but i will check.Also the clicking noise goes away when the engine is hot, or at least i can't hear it. It is not loud so i think that it might be valve since after it heats up i can't hear the clicking. If so how would i fix the problem? rebuild the whole head? My car has 149700 miles on it, i really don't wana take it to a shop. How hard is it to find the bad valve (if bad) and fix it , provided i have some mechanical knowlwge and acces to alldata and the chilton manual? How expensive is a rebuild kit for the head and how hard is it to do it .
Thanks guys.
StPapp
Tunes67
Post by Tunes67 »
You my friend have a bit of research in front of you.. But I will get you started.. likely the ticking sound you are hearing is your HLA's.. pretty common in a engine with that high of mileage. HLA = Hydraulic Lash Adjuster or as more commonly called, Lifters. Now.. I am not positive the SOHC engine has HLA's to be honest.. thats where the research comes in ;) Use the search button up top and start by searching for something like "SOHC HLA's" Or some such.. or maybe a bright fellow by the name of 93SOHC can shed a more positive light on this. As for the rebuild.. most folks will tell you that engine is not really worth the expense.. and.. well.. they are a dime a dozen and you can buy a complete replacement engine for $400 or less. Which is a LOT less cash than you will spend on a head rebuild for your current engine. But probably the first thing you should do is a compression test. This is a very easy test to perform and it will give you an idea of what condition your valves are in. You can buy a compression tester anyplace you can get tools or auto parts. Here is how you do it...
1) Unplug the wiring harness from your distributor
2) Disconnect your spark plug wires - make note of where each one goes
3) Remove all 4 spark plugs
4) Screw in the compression tester to #1 cylinder
5) Have a friend crank the engine over until the needle on the tester no longer moves up.
6) Repeat steps 4&5 for the remaining 3 cylinders. Making sure to record your results.
7) Reinstall your spark plugs, attach your plug wires in the correct firing order and plug the wiring harness back into your distributor.
Now.. what you want to see are relatively even numbers.. a 10 psi difference between cylinder results isnt too bad for a engine of your mileage. However.. if you find the varience to be more than that.. or if one or more cylinders reads extremely low.. it can indicate that your valves are not sealing properly. For a engine of your mileage.. assuming regular oil changes and decent upkeep.. I would expect to find at least 135 Psi per cylinder. Higher than this is great especially if all of your cylinders are higher. Now if you find something like.. 150, 145, 40, 155 across your cylinders.. # 3 cylinder (reading from left to right) has some serious issues. Likely a burned valve.
If you find the results of your compression test to be unsatisfactory.. I would recommend replacing the whole engine rather than dinking with a head rebuild. Especially if you can do the engine swap yourself. You could also take the opportunity to upgrade to a more powerful engine if you wish. This again is where the search function will come in handy for you :) Hope this helps.
Tunes67
"So long.. and thanks for all the fish!" "Momma says VW Bugs are the devil" "This one time at band camp.. I stuck a flute in my Throttle Body" ;)
neutral
Re: CLICKING NOISE
Post by neutral »
plusinfinit wrote:I have a slight clicking noise that sounds in a very metalic way. Also the clicking noise goes away when the engine is hot, or at least i can't hear it. It is not loud so i think that it might be valve since after it heats up i can't hear the clicking...
Besides valvetrain noise, could be your timing belt idler/tensioner pulley making a racket. When badly worn this can produce a pretty loud distinctive ticking sound that often disappears completely (for a while) as the motor warms up.
Were these parts replaced when the timing belt was changed? If not, consider buying an inexpensive mech's stethoscope from almost any autoparts store (<$20 USD) and pinpoint the noise. If it's def coming from the timing belt path (pass side of engine) might not be valves after all.
Image -Jim
plusinfinit
I will buy the stetoscope, the tensioner is old, and i beleive that some of my pulies have bad bearings. The car runs strong, awsome for its age, no leaks no smoking. I will geta stetoscope tomorow.
Thanks will keep u guys updated.
StPapp
D323
Post by D323 »
