no idle
goldsberry1
no idle
Post by goldsberry1 »
ok i reinstalled my intercooler pipes and changed out two temp sensors. now when i start it it dies unless i keep it the rpms up. it will die right away if i dont. i adjusted the idle screw on the im and got it to idle for a little bit but it still died. then i started it back and it was doing what it was before. i mean it ran with the turbo pipes before so i dont understand. if i cant figure out whats wrong soon i'm going to sell this and get a honda civic. i bet they are easier to work on.
92' mx-3 gsr, built engine, forged internals, p/p ze heads. t3/t4e .63/.60 turbo, udp, msd ignition, millenia s injectors, millenia im, water cooled intercooler, afpr, fmu. running at 7 psi right now
jschrauwen
Post by jschrauwen »
Sounds like a question for the boosted guys and in particular for Steve (babybluemx3). FWIW, I may want to try a TPS adjust or maybe put it into diag mode and re-adjust the idle screw again and see if it takes or is recognized by the ECU. Just a wild guess.
goldsberry1
well the turbo isnt really in. right now its waiting to be rebuilt so i'm just running the intercooler and pipeing. so the engine is actually n/a right now
