Help BP Wont start
Help BP Wont start
ok firing order is correct. I have spark and the starter is turning but it doesnt fire... any ideas?
Management is not responsible for lost or stolen virginities.
White 94 Mx-3 BP
Black 93 Mx-3 Kl-De
White 94 Mx-3 BP
Black 93 Mx-3 Kl-De
- ryanlindenberg
well spark + fuel = fire, you have spark so you must be missing fuel. is your fuel pump working? plugged filter maybe?
CARDOMAIN WITH UPDATED PICS
- Typhoonk
Check fuel.
1. Make sure EVERYTHING IS CONNECTED. double check
2. Crank over engine five or so times.
3. Unplugg fuel pump connector
4. Crank engine over a couple of more times to releive fuel pressure a bit.
5. At the fuel rail double check you have the fuel hoses attached to the right sides. Then Remove the return line from the fuel line (use a cloth over it so you don't get fuel sprayed into your face)
6. If you got fuel leaking (and fuel sprayed out cause there was pressure) then u are ok.
My guess is you forgot to ground something. Check the ground straps then, as someone else how to check to make sure your making a spark
PM for info
PM for info
matt_fulghum
you primed the fuel lines right?
this has happened to a couple people because they forgot to jumper the fuel pump plug in the diagnostic box and prime the lines.
my cardomain site: http://www.cardomain.com/memberpage/793483
matt_fulghum
